smog check fail - Mustang Evolution
Old 02-25-2013, 06:52 PM   #1
smog check fail
Need some help. My gf got a used car but failed the smog check. Now what.? Does she has to fix it till it passes or can she return it to the guy she bought it from?
Andy714 is offline   Reply With Quote
Old 02-25-2013, 06:56 PM   #2
Sanguin's Avatar
That's a state issue. I don't have smog testing here, so I can't advise.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 02-25-2013, 07:00 PM   #3
Venomouz831's Avatar
Did the previous owner gave her the smog when they did it? Why doesn't it pass? Cel?
)02 Gt, Founder of WE2G
Old 02-25-2013, 07:03 PM   #4
No they didn't give her smog paper.. it says fail on the rpms.. its getting 759 and its supposed to get 250ish..I don't know what that means its on the paper.. the car seems to run good with no dash lights on
Old 02-25-2013, 07:08 PM   #5
Boomdizzle's Avatar
An oil change can make a big difference on the smog checks. Also drive it around for an hour or so on the highway before you take it in to get it tested. I passed the e-check we used to have here in my old fox body and I didn't even have Cats doing those 2 things lol.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 02-25-2013, 07:14 PM   #6
Xtrosity's Avatar
Well I know in Cali you are required by law to include a smog check that has passed within 90 days when selling a car. Quite a few don't do this, so it is a risk when buying a car without one, putting you in a situation like this. What is it that is running high? It could be something about the cats, coolant, oil, ect. Need a little more info to really be of help.
Xtrosity is offline   Reply With Quote
Old 02-25-2013, 07:25 PM   #7
What should I check?? I'll be changing the oil soon. So if it can't pass the smog check she can return it ??
Old 02-25-2013, 08:03 PM   #8
Xtrosity's Avatar
If it came from a dealer you might be able to pressure them to return it, if not you guys bought it as-is. It could even be a thermostat stuck open. My fathers truck failed due to a stuck thermostat keeping gas sticking to the cylinder walls resulting in high hydrocarbons I believe. It could be one of quite a few things. I would start with a tune up and some regular maintenance.
Old 02-25-2013, 08:06 PM   #9
Fintile's Avatar
Those number I believe are your pollutant numbers. In order to pass you have to be between a certain range. Depending on how old the car is I would have your cats checked maybe even just replaced. .
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Fintile is offline   Reply With Quote
Old 02-25-2013, 08:21 PM   #10
It was some guy on craig'slist.. this weekend ill start by changing the oil and spark plugs... Thanks guys for the help
06:10 PM
