streached clutch cable - Mustang Evolution
Old 03-24-2013, 05:26 PM   #1
01mustang_gtfun's Avatar
Does anyone know where I can order a non cheap clutch cable,by non cheap I mean one that's not gonna streach or break as soon as I put it in.I have an after market clutch..any suggestions would be nice thanks
01mustang_gtfun is offline   Reply With Quote
Old 03-24-2013, 05:27 PM   #2
NewMtang's Avatar
Ford Dealer?
Old 03-24-2013, 05:30 PM   #3
I don't want a stock cable if I can find a better one
Old 03-24-2013, 05:43 PM   #4
Oem is the best available.
Old 03-24-2013, 05:46 PM   #5
Is there a site I can order that from? Or do I just type in OEM.com?
Old 03-24-2013, 06:05 PM   #6
Ghostedmind's Avatar
OEM for a mustang is Motorcraft, or Ford racing, OEM means Original Equipment Manufacturer
---------- Post added at 06:05 PM ---------- Previous post was at 06:04 PM ----------
So, Fordparts.com or any auto parts store should have it
LCMC Member
Old 03-24-2013, 06:15 PM   #7
Oh ol thank u very much
Old 03-24-2013, 06:26 PM   #8
03RedfireGt's Avatar
maximum motor sports. Clutch cable. It is an Oem cable
03RedfireGt is offline   Reply With Quote
Old 03-24-2013, 09:02 PM   #9
I have a heavy duty after market clutch..should I go with a stock cable????
Old 03-25-2013, 04:49 AM   #10
I have a heavy clutch setup to. Centerforce dual friction, an a Fidanza racing flywheel. I done alot of research. Maximum Motor Sports cable had the best reviews that I could find. And it is an Oem cable. That's what I am going to put in mine along with the quadrant an cable adjuster. To answer the question, stock cables r the strongest cables imo
Old 03-25-2013, 08:02 AM   #11
I have a spec 3+, fiore firewall adjuster, steeda quadrant. Oem cable has held up to my abusive driving, i'm probably harder on it than most drivers.
Old 03-28-2013, 07:41 PM   #12
Ok thanks for the help guys
08:48 AM
