Somebody help please - Mustang Evolution
Old 05-20-2013, 07:23 PM   #1
2003SonicBlue's Avatar
For the past few months if I accelerate to 4,000RPM my battery light will come on. Has anyone else experienced this or maybe know what the cause could be? Thanks for the help!
2003SonicBlue is offline   Reply With Quote
Old 05-21-2013, 01:00 AM   #2
Venomouz831's Avatar
Make sure you're battery is tightened I had the same problem in my 02 gt on wot the icon would come out as well. And what you showing in the pic?
)02 Gt, Founder of WE2G
Old 05-21-2013, 01:10 AM   #3
Nothing just took a picture of my dash and I work at an Auto Parts store and In the past year I replaced my alternator, battery, belt, and both terminals. Still don't know what the problem could be...
Old 05-21-2013, 08:02 AM   #4
BIGHOSS5.0's Avatar
Double check all your connections and make sure they are tight. Check both ends of your ground/black/negative battery cable. If not that go to autozone and have them run a diagnostic, they might be able to tell you what the problem is. I think they will do a diagnostic for free...
BIGHOSS5.0 is offline   Reply With Quote
Old 05-21-2013, 08:23 AM   #5
MidnightBlueGT's Avatar
+1
Might just be something as simple as tightening cables, hopefully
Old 05-21-2013, 11:24 AM   #6
Like I said I work at an auto parts store. I've ran all the tests from my store that I can. I work at Advance Auto Parts. And I put in batteries every day in customers cars and I know everything is solid and good. It doesn't make sense and nobody knows what the fix is
Old 05-21-2013, 12:06 PM   #7
BIGHOSS5.0's Avatar
Well in that case, you may want to check you belts and tensioners...Make sure they are not loose, you could be having belt slip at higher RPM.
Old 05-21-2013, 12:46 PM   #8
BIGHOSS5.0's Avatar
Something else I just thought of...My wife's old Taurus's A/C compressor was going bad and went it got down to the last days I would notice the battery light coming on...it was because it was locking up and causing the belt to slip...Hope this helps...
Old 05-21-2013, 01:42 PM   #9
Belt is new as I said and I'm having no slipping.
Old 05-27-2013, 01:04 PM   #10
Found out what was wrong, the new alternator i put in was bad
Old 05-28-2013, 09:32 AM   #11
BIGHOSS5.0's Avatar
Cool, glad you got it fixed
09:00 AM
