Latch problem on hood? - Mustang Evolution
Old 05-31-2013, 10:49 AM   #1
sLbxO143's Avatar
It seems as if when I shut my 04 hood I have to slam it from way up top, which doesn't seem right to me to have to slam the hood for it to latch and close. Am I possibly missing something that locks the hood? It does lock but only when I slam it. Is there normal for mustangs or something Is wrong
sLbxO143 is offline   Reply With Quote
Old 05-31-2013, 11:32 AM   #2
zinc_yellow's Avatar
Region: New Mexico
My hood does the same thing on my 02
zinc_yellow is offline   Reply With Quote
Old 05-31-2013, 11:33 AM   #3
Mile high JDF's Avatar
I believe Ford had a TSB out on it. If I remember correctly then you just need to put some shims under the latch to raise it up a bit.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-31-2013, 11:35 AM   #4
Venomouz831's Avatar
Same thing has been with all my mustangs.
)02 Gt, Founder of WE2G
Old 05-31-2013, 12:29 PM   #5
Brandon280's Avatar
Mine needs a little more force after i installed the hood struts. I guess the extra 1/16" moved it just enough..
Brandon280 is offline   Reply With Quote
Old 05-31-2013, 02:22 PM   #6
sLbxO143's Avatar
So it seems to be a common problem on all mustangs so I guess slamming it is the way to do it. Thanks for the input
Old 06-01-2013, 11:12 AM   #7
dudeitsdylan's Avatar
Send a message via MSN to dudeitsdylan
I just sit my down and then just push down and it closes with ease. I barely have to use any strength.
dudeitsdylan is offline   Reply With Quote
Old 06-01-2013, 02:54 PM   #8
sLbxO143's Avatar
I wish that was the case with mine. You have to slam it to lock it that's why I thought maybe I was missing a locking piece. That's how hoods should shut with not so much force.
Old 06-01-2013, 03:03 PM   #9
It's just a new edge problem. As I said earlier it just need shims or washers put under the latch to make it latch correctly.
Old 06-01-2013, 03:54 PM   #10
sLbxO143's Avatar
Do you know where I could buy those and where do I exactly put them?
Old 06-01-2013, 04:21 PM   #11
Here's a link to the actual TSB and how Ford says to fix it, you just need to find washers that fit the mounting bolts and will raise the latch up. http://forums.corral.net/forums/gt-s...-99-cobra.html
Old 06-01-2013, 07:52 PM   #12
sLbxO143's Avatar
Thank you so much you were an awesome help
Old 06-01-2013, 07:54 PM   #13
Glad I could help. I take it that you got it fixed?
Old 06-01-2013, 07:55 PM   #14
sLbxO143's Avatar
Not yet I am at work but tomorrow is my day off but with the link you sent me with that info I'm sure I can get it fixed tomorrow.
Old 06-01-2013, 08:00 PM   #15
Good luck!!
08:33 AM
