Break in 87 or 91 Octane - Mustang Evolution
Old 06-03-2013, 06:26 PM   #1
ford302ize's Avatar
Hi I just got a 14' GT last Friday and would like to know what fuel octane I should use for the first 1,000 miles. The owners manual says that 87 is recommended, but in extreme temperatures or high performance driving 91 should be used. Which one should I use?
My Toys. 2014 GT Base with Manual Trans. Borla S-Type Axle Backs. 2005 Honda VTX 1300C.
ford302ize is offline   Reply With Quote
Old 06-06-2013, 08:44 AM   #2
BigB227's Avatar
With the break in of an engine I've always heard to take it easy and lug the motor a bit, not really any high rpm drives, and I would say 87 would've good for the break in. After that if you wanted to switch to 91 it would be good
BigB227 is offline   Reply With Quote
Old 06-06-2013, 02:51 PM   #3
Gordito's Avatar
Aww.. too late for me, I didn't read that.. I started using 91 from the beginning.. I wonder what the dealer put in it since they filled it up for me when I bought it..
Gordito is offline   Reply With Quote
Old 06-06-2013, 04:27 PM   #4
BaSohol's Avatar
Dealer likely used 87
2007 Ford Mustang GT 5spd
Old 06-06-2013, 04:35 PM   #5
MidnightBlueGT's Avatar
+1
dealers are in the business to make $ and most try to get out with spend the least amount of their own $ as possible.
Old 06-06-2013, 05:00 PM   #6
The Blue Dragon
GrabberBlue5.0's Avatar
There's a thread about this exact same thing in the 10-14 section. In a high compression motor like the 5.0 I would never run less than 91.
Just because the ecu can ****** timing and "allow" you to use 87 octane doesn't mean you should. It's a bandaid fix for using cheap/low octane gas that will lead to long term damage and faster wear
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-06-2013, 06:05 PM   #7
Gordito's Avatar
Originally Posted by MidnightBlueGT View Post
+1
Well then at least it had 87 for the 1st 300ish miles(car came with 100 miles already...)
10:06 AM
