Fast blinking indicators? - Mustang Evolution
Old 06-05-2013, 11:18 PM   #1
Ok so sometimes when i use my left signal to change lanes it will flash really fast. I know they are supposed to do this when a headlight or tail light is burned out, but i checked and when it does this both my headlight and tail light are working normally, just flashing extra fast. Is this something to do with the wiring some how? Its only on the left indicator, and it doesn't do it all the time. But when it does it, it will do it for a while, then just go back to normal and then act normally for a while again.
Any help appreciated.
Old 06-05-2013, 11:25 PM   #2
Robbiemustang96's Avatar
it doesn't mean that its burned out. it means its on its way to being burned out. but in my moms 2006 fusion her signal lights started flashing quickly and so we replaced all the bulbs but no fix. we had to put a new Computer in it and it fixed it.
Robbiemustang96 is offline   Reply With Quote
Old 06-05-2013, 11:39 PM   #3
Tyoung68's Avatar
Could be just a bad connection
Old 06-08-2013, 05:29 PM   #4
Silver06GT's Avatar
Do you have aftermarket sequential turn signals? Mine started doing this, wiring harness ended up being bad.
Silver06GT is offline   Reply With Quote
Old 06-08-2013, 07:19 PM   #5
Nope, stock
Old 06-08-2013, 08:04 PM   #6
Terminator's Avatar
Maybe one of your dual filament bulb is partial burnt out as in, its on when running lights are on but not lit when brakes are applied
Terminator is offline   Reply With Quote
Old 06-10-2013, 12:45 PM   #7
Xaperez100's Avatar
Try replacing the bulb.
If no fix then replace the flasher.
It's right behind the center console next to the gas pedal
Xaperez100 is offline   Reply With Quote
Old 06-10-2013, 09:51 PM   #8
Bulbs are brand new. And I'm at camp and won't see my car for 9 weeks so I'll have to do it then.
Old 06-10-2013, 10:01 PM   #9
Gera8712's Avatar
Assuming everything is stock(harnesses,bulbs-non leds,flasher,etc)
I'd check the dimmer switch
Gera8712 is offline   Reply With Quote
Old 06-11-2013, 12:58 AM   #10
Xaperez100's Avatar
Dang that's a long time!
Old 06-11-2013, 06:49 AM   #11
KARgt13's Avatar
Fuse could be on its way out
KARgt13 is offline   Reply With Quote
05:05 AM
