Maintainig your stang?? - Mustang Evolution
Old 06-15-2013, 04:33 PM   #1
FortyBrandon's Avatar
I was over due 3k on miles for oil cha he and when I went they said I had lost a rear end seal was leaking and my tranny seal was leaking. I never noticed either but he said my rear end was wet. They were pretty low and I did not know it. What are some have to things to check on your car??
FortyBrandon is offline   Reply With Quote
Old 06-15-2013, 04:41 PM   #2
Venomouz831's Avatar
The obvious fluids under the hood, oil, coolant, ps, brake fluid. Check you're diff for any leaks as well
)02 Gt, Founder of WE2G
Old 06-15-2013, 04:56 PM   #3
fastmustangs1's Avatar
Yes all fluids. I also check ball joints, tie rods, bushings filters etc.
fastmustangs1 is offline   Reply With Quote
Old 06-15-2013, 05:58 PM   #4
Evil2014GT's Avatar
Air and fuel filters as well.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 06-15-2013, 06:04 PM   #5
Is a rear differential leak bad?
Old 06-15-2013, 06:09 PM   #6
Evil2014GT's Avatar
Not immediately, but eventually yes. If there is not enough fluid in there to lubricate the gears, axles, and differential, then you will have serious repairs on your hands. Where did you take the car. Did you verify that it was leaking? Alot of lube shops will try and BS you in order to get more work.
Old 06-15-2013, 06:13 PM   #7
They told me my transmission seal was leaking and the rear end was soaked. At first he said it may be from the tranny but he said the rear end differential and tranny was low. I think he said they were both on there last quart or something and he said they hold like two or three idk. I had them put more in and they told me I should get it looked at because the transmission and rear end would have to be replace if left like that
Old 06-15-2013, 06:17 PM   #8
Evil2014GT's Avatar
1 quart in the diff???? Lol i think you would have heard some grinding if that was true. Like i said, where did you take it? Sounds like they were exaggerating a bit. Not to say that they aren't really leaking tho. I would go a shop that you trust and get a second opinion. If it's just the diff cover that's leaking, that's a cheap fix. Could be your pinion seal tho. And as far as the trans, where they talking about your rear main seal? That repair will be a bit pricey.
Old 06-15-2013, 06:23 PM   #9
Idk ill have my mechanic look into it. What causes it?
Old 06-15-2013, 06:34 PM   #10
Evil2014GT's Avatar
Hard to say. Most likely just wear and tear. How many miles on the car?
Old 06-15-2013, 06:38 PM   #11
118 now.
Old 06-15-2013, 06:42 PM   #12
Evil2014GT's Avatar
118 now.
Yeah probably just normal wear and tear bro
Old 06-15-2013, 06:43 PM   #13
Does your car still have irs? If so expect $500-600 to reseal the diff cover...
Old 06-15-2013, 06:49 PM   #14
Evil2014GT's Avatar
Oh s*** does he have a cobra?? Didnt think there were any other mustangs with irs.
Old 06-15-2013, 06:50 PM   #15
Yeppers. ;( I guess I should call that woman up and sell it for 6 lol!
Old 06-15-2013, 06:58 PM   #16
Evil2014GT's Avatar
Oh sorry man, didnt know it was a cobra. Yeah with that irs its gonna cost ya quite a bit more. Are you the guy who had the one with the rebuild title? I read that thread earlier. Yeah at this point, i would definitely take the $6k and be done with it haha
Old 06-15-2013, 06:59 PM   #17
The diff has to be removed from the irs assembly. Halfshafts pulled, etc. Quite the time consuming process.
Old 06-15-2013, 07:00 PM   #18
Evil2014GT's Avatar
Yeah it sucks. Had to do it on my gto.
Old 06-15-2013, 07:00 PM   #19
;( ill try and make it last as long as I can.
05:26 AM
