Dealership problems! - Mustang Evolution
Old 07-03-2013, 03:12 PM   #1
arturo55's Avatar
So the Dealership called me saying that the second gear was wore down and it was not cover in the Warranty can I fight this?
arturo55 is offline   Reply With Quote
Old 07-03-2013, 03:19 PM   #2
what are your mods?
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 07-03-2013, 03:20 PM   #3
Midnight2012's Avatar
Originally Posted by arturo55 View Post
So they called and told me that the transmission second gear was wore down and it's not cover under warranty can I fight this?
Why?
Midnight2012 is offline   Reply With Quote
Old 07-03-2013, 03:49 PM   #4
What was the reasoning for this?
SigStang is offline   Reply With Quote
Old 07-03-2013, 05:35 PM   #5
arturo55's Avatar
I have no mods my car is still stock
Old 07-03-2013, 05:39 PM   #6
What was the dealerships reason for not wanting to cover this issue?
Old 07-03-2013, 06:39 PM   #7
arturo55's Avatar
---------- Post added at 07:39 PM ---------- Previous post was at 07:38 PM ----------
Dddsxtbbga?bffx
Old 07-03-2013, 06:56 PM   #8
Gordito's Avatar
How many miles do you have? Just curious to see if I'm safe...
Gordito is offline   Reply With Quote
Old 07-03-2013, 07:01 PM   #9
Dddsxtbbga?bffx
I take it you really didn't want an answer to your question.
Old 07-03-2013, 07:22 PM   #10
arturo55's Avatar
What do you mean?
Old 07-03-2013, 07:30 PM   #11
What do you mean?
Well we've all been asking why they said it was t covered under warranty. Could make a difference on wether you should fight it or not.
Old 07-03-2013, 07:32 PM   #12
FastFord13's Avatar
If its still under warranty and there are no mods on it TELL them to fix it!!!!!!!!! If they don't want to fix it call ford USA/Canada and complain!!!!!!!
Old 07-03-2013, 07:36 PM   #13
351stroker's Avatar
No reason it shouldn't be handled by the dealership if its still on warranty. Hell I had a 98 Jeep in 99 and the rear end let go. They replaced it with a posi unit for $150, never had trouble again.
351stroker is offline   Reply With Quote
Old 07-03-2013, 07:53 PM   #14
^^^^^^^ this! I'm all ears as to how the reached the decision to not cover this.
Old 07-03-2013, 08:07 PM   #15
Ubnbit's Avatar
Why did they say they wouldn't cover it again? Lol
Old 07-03-2013, 08:32 PM   #16
arturo55's Avatar
Sorry I was at work I fixes it now
---------- Post added at 09:31 PM ---------- Previous post was at 09:30 PM ----------
7400
---------- Post added at 09:32 PM ---------- Previous post was at 09:31 PM ----------
So I should complain about it
Old 07-03-2013, 08:32 PM   #17
He said it was because Dddsxtbbga?bffx.
That's when you have to have the balls to say Fcck?u2ssbte
Old 07-03-2013, 08:33 PM   #18
arturo55's Avatar
Because they said it was abuse
Old 07-03-2013, 08:36 PM   #19
Alright then unless you admitted drag racing or abuse then yes call Ford direct. Sounds like the synchros went out and ground the gear. Clutch is fine? No make them prove it.
Old 07-03-2013, 08:39 PM   #20
Ubnbit's Avatar
Abuse? There are guys on here that drag the sh*t out of there cars and never have gear issues.
So honestly, we need to know how the conversation went at the dealership.
Old 07-03-2013, 09:20 PM   #21
arturo55's Avatar
All they said was that second gear was wore stripped down and Warranty doesn't cover that Consider it abuse and it will be 1900 to fixes
---------- Post added at 10:20 PM ---------- Previous post was at 10:19 PM ----------
I've done neither
Old 07-03-2013, 09:31 PM   #22
I agree with Midnight 2012 on this one, fight this till the bitter end! 1900 dollars is nuts. I would say get a second opinion but that would mean they would need to tear down the tranny again.
Old 07-03-2013, 10:03 PM   #23
VIG
VIG's Avatar
Region: Delaware
I feel like we might be missing some details here because I can't imagine them just coming straight out and saying that. Especially considering you have like 7600 miles on the car.
There's no way you should have left there without a fight.
What exactly was said? Did they ask you about your driving style or anything? Did you mention you drive hard?
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 07-04-2013, 06:00 AM   #24
arturo55's Avatar
Before they tore down the transmission he called me and asked me if there was any modifications done to the car And I said no the only thing that's been done to the car is just The exhaust
Old 07-04-2013, 10:00 AM   #25
arturo55's Avatar
Bump
Old 07-04-2013, 02:01 PM   #26
Region: New Mexico
Arturo, something does not seem right. Is there evidence of extreme tire wear or any other circumstances that would lead them to believe you have been abusing the vehicle?
It seems unreasonable that they would summarily refuse to warranty your transmission with few miles.
There's more to this. But, if you feel you have not been beating the snot out of the car, call Ford.
Six7One is offline   Reply With Quote
Old 07-04-2013, 02:42 PM   #27
VIG
VIG's Avatar
Region: Delaware
If this is truly the whole story, then you need to get your boxing gloves on.
They can't base warranty work upon speculation of how they think someone drives.
Old 07-04-2013, 03:17 PM   #28
arturo55's Avatar
i found a video what my car was doing
this guy only has 5000 miles and ford didnt want to warranty neither
Old 07-04-2013, 04:49 PM   #29
Ubnbit's Avatar
Either way, I would fight it. The fact of whether or not it's from abuse, really is not my thought. I'm thinkin that with that few miles, how much abuse could have been done?
Have u talked to ford again?
Old 07-04-2013, 05:11 PM   #30
arturo55's Avatar
its fourth of july there closed but im going to let my mom and my sister in law take care of it, i think because im 19 they see me as a kid but still i think its wrong
Old 07-04-2013, 05:35 PM   #31
Ubnbit's Avatar
I'd be there to defend myself if they accused.
Old 07-04-2013, 07:47 PM   #32
NewMtang's Avatar
On July 2nd, at 07:34 PM, You (arturo55) posted in response to SigStang, No mods still stock I haven't change anything
On July 3rd, at 07:35 PM you posted: I have no mods my car is still stock
On July 4th, 08:00 AM, you told who ever called from the dealership(the day before), only thing that has been done to the car the exhaust.
As it seems several others in here are lost trying to follow you. Is there any other things that have been done to your car?
Old 07-04-2013, 08:25 PM   #33
arturo55's Avatar
no still stcok
Old 07-05-2013, 12:55 AM   #34
Yep you're right. Mom knows what to do!
Old 07-05-2013, 10:33 AM   #35
formulaDstang's Avatar
Last time I checked if the car is under warranty and a oem part fails, breaks it should be fixed unless its an aftermarket part that causes the problem then its not covered. I would talk to the manager of that dealership and tell him what's going on and if they don't fix it tell them to kiss you a$$ and go to a different dealership.
formulaDstang is offline   Reply With Quote
11:02 AM
