Best way to remove plasti dip? - Mustang Evolution
Old 07-18-2013, 09:21 AM   #1
sLbxO143's Avatar
I read on other forums WD-40 will soften it up then just peel it off? Will this work because it is so caked on there it won't just peel.
sLbxO143 is offline   Reply With Quote
Old 07-18-2013, 10:32 AM   #2
I thought the trick was just spraying on 4-5 coats so it would peel off easy
Old 07-18-2013, 10:47 AM   #3
emery2483's Avatar
it should just peel up of you did it right...
emery2483 is offline   Reply With Quote
Old 07-18-2013, 10:53 AM   #4
larrimus's Avatar
Supposedly, if it's being stubborn, you can spray on a fresh coat and use that to peel off the old. I've never used the stuff so I can't speak from experience.
If that doesn't work, possibly a pressure washer?
larrimus is offline   Reply With Quote
Old 07-18-2013, 11:29 AM   #5
Black8thElement's Avatar
The more layers the easier it is to peel off. If its lightly shaded it will be a b!tch to get off. You don't need WD-40 unless you like to huff that ***** lol, a simple dry towel and finger nails to pinch and pull away. P.s have somethin to dump the waste in , you don't want to see little pieces of black plasti scattered around in your drive way very annoying
Black8thElement is offline   Reply With Quote
Old 07-18-2013, 12:09 PM   #6
sLbxO143's Avatar
That is the biggest advertising lie I've ever read. That **** did not peel at all and there was more than 5 coats on it. I did end up getting it off but I know I'm never putting it back on
Old 07-18-2013, 12:17 PM   #7
Adogg's Avatar
^^ no offense but you must have done something wrong my friend. What did you plasti dip? I have peeled plasti dip off more times then I can remember and it never really gave me any trouble.
Don't hate....... appreciate
Old 07-18-2013, 12:20 PM   #8
sLbxO143's Avatar
Rear valance, I mean you can't really **** up plasti dip. Tape off the area, spray it and peel the tape lol. Just doesn't come off easy because I did over 5 coats. Oh we'll it's off now. If everyone had such an easy time I wouldn't of found so many threads on other forums of ways to get it off.
Old 07-18-2013, 01:06 PM   #9
You probably had light coats. I have had it do **** like that to me before, but the next time i used it i sprayed more coats and thicker coats and when i peeled it off it came right off with no hassle.
01:07 PM
