Dumped exhaust good or bad idea? - Mustang Evolution
Old 08-03-2013, 07:32 PM   #1
94gtconvert's Avatar
I recently found some axle dumps for free and am considering slapping them on. I have a bbk x pipe no cats and flowmaster super 40's. if I put the dump tip right on the exhaust outlet will it sound bad? How loud will it be over a axle back tail pipe?
94gtconvert is offline   Reply With Quote
Old 08-03-2013, 08:32 PM   #2
02NightmareGT's Avatar
When I had dumps all it did was make it louder on the inside and quieter on the outside. Vibrates the seat too. There also wasn't any tone to the exhaust anymore it was just gurgly. I have the same set up as u. Don't get dumps
---------- Post added at 08:32 PM ---------- Previous post was at 08:31 PM ----------
It also reduces back pressure therefore reduces performance
02NightmareGT is offline   Reply With Quote
Old 08-03-2013, 10:41 PM   #3
Reason enough thanks for the input
Old 08-04-2013, 01:18 AM   #4
Mile high JDF's Avatar
Back pressure reduces performance.... It doesn't increase it. I agree that dumps are pointless. Itt's gonna sound loud as hell and you're gonna have issues with the exhaust dimes rolling back into the car while sitting at a light.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-04-2013, 02:26 AM   #5
austinknoll's Avatar
Back pressure does not increase performance in any way. The myth that it increases torque is false. Why do you think race cars have free flowing exhaust systems?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 08-04-2013, 08:52 AM   #6
Old 08-04-2013, 08:59 AM   #7
ToHellAndBack's Avatar
That's what I said... Where did I say it increases performance? I said it reduces performance
---------- Post added at 08:52 AM ---------- Previous post was at 08:51 AM ----------
Again... That's what I said... Where did I say it increases performance?
You said that dumps REDUCE back pressure and reduce performance. If you REDUCE back pressure performance will increase. Needing back pressure is a myth. You lose performance when you reduce exhaust velocity, not back pressure
"I'm not tailgating... I'm drafting"
ToHellAndBack is offline   Reply With Quote
Old 08-04-2013, 09:05 AM   #8
O I read it wrong
03:43 AM
