Shorty Header Installed!!! - Mustang Evolution
Old 08-20-2013, 12:31 AM   #1
silvrbullet2012's Avatar
So awhile back I ordered these and just came in today.
Took me pretty much half the day due to small complications. But it was well worth it!!
Being a 50k mile car my nuts seized on the studs and came out with them. Lol. But no big deal. Took them apart and put them back in.
What took the longest part was the passenger side is such a PITA with it being all cramped.
Please don't say "you should've gotten longtubes." I know what I wanted.
Have any question feel free to ask!
OH AND VIDEOS WILL BE ON MY INSTAGRAM
@37rogers
AND SOON ON YOUTUBE.
ID:	124795   Click image for larger version
ID:	124797   Click image for larger version
ID:	124799   Click image for larger version
silvrbullet2012 is offline   Reply With Quote
Old 08-20-2013, 05:15 AM   #2
Tyriqq's Avatar
You should have gotten LT......lol
Can't wait to get my shorties, but I won't be the one crawling up under my car.....lol
Tyriqq is offline   Reply With Quote
Old 08-20-2013, 05:38 AM   #3
David Young's Avatar
Looks good, a lot better than the cast iron slugs used for the factory exhaust manifolds
David Young is offline   Reply With Quote
Old 08-20-2013, 05:44 AM   #4
bucko's Avatar
Some tips for header installation: soak the bolts with PB blaster or equivalent overnight to help them come loose. On our 3.7 V6, remove the upper intake to make installation of the passenger side much easier.
Old 08-20-2013, 06:40 AM   #5
Tyriqq's Avatar
If the upper intake is removed, is everything accessible from the top side for installation?
Old 08-20-2013, 06:43 AM   #6
rebeltx's Avatar
Didn't think about pulling the upper. That's a good idea
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 08-20-2013, 08:30 AM   #7
bucko's Avatar
At least the manifold to head bolts. Not sure about the bolts to the down pipes.
Old 08-20-2013, 09:58 AM   #8
Thanks for the tip I was going to soak them but forgot that night and was a lil impatient to put them on. Haha.
Removing the top intake manifold would've helped a lil but the main thing getting in the way is the damn line that ran across the passenger side.
The bottom bolts are really hard to tightin since your just in a awkward position. But it can be done.
Old 08-20-2013, 02:24 PM   #9
Before install.
BBK catted xpipe and magnaflow comps.
After install
BBK shorty headers,BBK catted xpipe,magnaflow comps.
Make sure to turn the HQ on since its phone quality -_-
Old 08-20-2013, 02:30 PM   #10
Whitelightning's Avatar
Remember to soak your gaskets before install. If not, they will crack. Then you gotta pull them off and such all over again.
Old 08-20-2013, 02:36 PM   #11
RocknCali's Avatar
soak em in what?
RocknCali is offline   Reply With Quote
Old 08-20-2013, 02:58 PM   #12
Charlie_santos's Avatar
Originally Posted by RocknCali View Post
soak em in what?
Preferably Unicorn Piss, it gives you 50 extra HP at Zero RPM jk idk hahahqha
---------- Post added at 02:58 PM ---------- Previous post was at 02:58 PM ----------
@37rogers
Nice but rasp n crackling n stuff I hate that. But u may like it
Old 08-20-2013, 03:47 PM   #13
Most likely it's from my xpipe. If they made a H and some resonators it wouldn't be bad. But I like the lil crackle.
Old 08-20-2013, 03:54 PM   #14
13 stang22's Avatar
Charlie clear some messages. I need some advice on nitrous bro.
13 stang22 is offline   Reply With Quote
Old 08-20-2013, 06:37 PM   #15
soak em in what?
Water. Helps mold is to the engine instead of a dry install. Some old school guys can confirm this?
Old 08-20-2013, 07:04 PM   #16
RocknCali's Avatar
but that's with the paper gaskets I want metal; I think copper. are those better?
sorry for thread jacking OP
Old 08-20-2013, 07:17 PM   #17
NewMtang's Avatar
Did you get the stainless steel or the ceramic ones? I opted for the ceramic myself.
---------- Post added at 09:17 PM ---------- Previous post was at 09:16 PM ----------
Did you buy the paper ones separately? The metal came with mine.
Old 08-20-2013, 08:18 PM   #18
Intense.'s Avatar
Either reuse the stock manifold gaskets (what I did) or get new oem manifold gaskets. You won't beat Multi Layer Steel gaskets on sealing or longevity. Throw the BBK composite gaskets where they belong, in the trash. As far as copper...it anneals, and can blow out over time after many heat cycles. It is conformable to an extent though but still, oem is better. Otherwise...oem would use copper. Just like MLS head gaskets...MLS manifold gaskets are the best route.
'14 Race Red GT M6, premium, comfort package, Steeda stb
Intense. is offline   Reply With Quote
Old 08-20-2013, 08:30 PM   #19
It helps with molding it. Either way, I'm doing a wet install.
Old 08-21-2013, 12:00 AM   #20
This is actually interesting. I never heard about wet install of gaskets. I've never done it before. I was going to go get new metal gaskets but didn't feel like getting them. Lol
Old 08-21-2013, 01:27 AM   #21
Good to go sir
Old 08-21-2013, 04:54 AM   #22
bucko's Avatar
Neither have I. I've installed quite a few headers, albeit its been a few years. Saking a composit gasket would seem to make it weak.
I like the idea of using the OEM gaskets of today. Much better quality then they used to be. I can even remember cork!
Old 08-21-2013, 08:09 AM   #23
So we can use the oem gaskets? For some reason I thought they wouldn't fit lol
That's what I'll use then.
Old 02-10-2014, 11:28 AM   #24
sunnytan06's Avatar
Any performance gain?
sunnytan06 is offline   Reply With Quote
Old 02-10-2014, 10:17 PM   #25
NewMtang's Avatar
That's TRUE except he is West of the Mississippi. So you will have to use only MALE Unicorn Urine, otherwise, you will only be getting 40 HP at Zero RPM.
02:34 AM
