Burning Oil - Mustang Evolution
Old 09-16-2013, 09:31 AM   #1
Luke02GTmustang's Avatar
Burning Oil
well, my 02 GT seems to be burning oil. after a stop light I'll go to take off and see big puffs of blue smoke come out the exhaust. also put a borla catback on and the 4" polished tips are covered with a dark color.
Luke02GTmustang is offline   Reply With Quote
Old 09-16-2013, 04:26 PM   #2
It's not good when your car is "smoking like a pregnant hooker in a bingo parlor".
Here in California, they won't pass emissions if there is any smoke coming from the tailpipe.
My recommendation is to start pulling the spark plugs and find out which cylinder or cylinders are the problem and go from there...
Old 09-16-2013, 04:28 PM   #3
okay. I just found out also that I have 21.5 fuel injectors. it's running rich might just need a tune.
Old 09-16-2013, 04:33 PM   #4
Well is it using an abnormal amount of oil?
I believe your car came with 21 lb injectors from the factory. Pink right?
They should not be causing smoke like you described...
Old 09-16-2013, 04:38 PM   #5
I really haven't seen a change at all. yeah, the later half of the year, Ford changed from 19lb to 21.5 and they are pink. I've read that it could just need a tune for the bigger injectors.
Old 09-16-2013, 04:53 PM   #6
They didn't change the tune when they went to the bigger injectors, so yes, your car probably runs a little rich at wide open throttle and could benefit, performance wise, from a tune.
I HIGHLY doubt that is the source of the blue smoke that you are seeing though, my friend...
Pull the plugs and look for any evidence of oil fouling.
And start checking your oil EVERY TIME that you fill up with gas...
Old 09-16-2013, 05:01 PM   #7
alright man. I appreciate the info!! it only smokes after I sit at a stop light or idle more than 15 seconds.
01:24 AM
