won't go into third - Mustang Evolution
Old 09-22-2013, 02:18 PM   #1
TXstang125's Avatar
won't go into third
I have a manual mach 1 and sometimes it won't go into 3rd anyone know what's wrong ?
TXstang125 is offline   Reply With Quote
Old 09-22-2013, 02:19 PM   #2
Rapinator126's Avatar
Is it while you are getting on it/ speed shifting. Stock shifter?
Old 09-22-2013, 02:27 PM   #3
TXstang125's Avatar
Yeah it's when I get on it, theres a MGW in it with the bump stops off , aftermarket clutch , steeda clutch cable with quadrant , the throw out barring is bad I'm getting it fixed soon
---------- Post added at 02:27 PM ---------- Previous post was at 02:26 PM ----------
And I made sure I was completely off the gas and clutch all the way it and it still just stoped there was a wall
Old 09-22-2013, 02:38 PM   #4
You have the Tremec 3650 correct? Those transmissions do not like to shift above 6k rpm, thats your problem. Its just a part of the transmission was a ****ty design so it is hard to shift past that rpm.
Old 09-22-2013, 02:43 PM   #5
TXstang125's Avatar
Yeah it's a 3650
Old 09-22-2013, 04:44 PM   #6
Damn, that third gear can be a Pesky MoFo...
Try draining the oil and refilling with only 3.2 quarts instead of around 4 quarts.
There was a TSB about this problem and Ford recommends using LESS oil to reduce the "windage" and, hopefully, solve the shifting problem.
Mobil 1 synthetic...
Old 09-22-2013, 04:49 PM   #7
TXstang125's Avatar
I put 4 quarts and it never showed up on the dip stick so Idk about 3.2 and GTX FTW !!!! Haha I tried shifting at diffrent points and it seems that that wall comes into play at 5 1/2k RPMs if I shift before then it goes right in
Old 09-22-2013, 04:56 PM   #8
There is no dipstick...
It sounds like this may be your problem. The oil is "slinging" around in there and making it hard to shift... Maybe.
Thats the cheapest thing to try to solve the hard shifting.
Old 09-22-2013, 05:01 PM   #9
Screaming Mach's Avatar
My throw out barring was going out I had the same problem I fix the barring and it shifts fine now
Screaming Mach is offline   Reply With Quote
Old 09-22-2013, 05:16 PM   #10
TXstang125's Avatar
Oh hahaha my bad I was talking about the engine oil lol I'll look at that where do u drain it and fill it ?
---------- Post added at 05:16 PM ---------- Previous post was at 05:15 PM ----------
I hope that's what it is I got the TB just gotta save up a little more for installation
Old 09-22-2013, 05:21 PM   #11
Yeah, don't just use 3.2 quarts in the engine.
There is a drain plug on the bottom of the transmission and a fill plug on the side of the transmission.
No guarantees, that's the only thing I can think of to try without tearing apart the car...
» Members Mustangs
13savage6
Lil6
austinh1999
Add your Mustang
04:52 AM
