Passenger Side Power Window Not Working - Mustang Evolution
Old 07-27-2008, 10:32 AM   #1
Hey what's up guys. My passenger side power window hasn't worked on my 94 mustang since I got it about a year and a half ago. Once in awhile though it actually does work perfectly for acouple days then just goes dead again. When I press the button, I don't hear anything from the window motor(doesn't spin). So i'm finally tired of it and want to fix it(dying in the heat). Based on what i've explained what do you guys think the problem is? i've seen bushing rebuild kits on ebay aswell and replacement motors. Someone also told me that I might have a short somewhere in the wiring or maybe even a dead fuse. Any help is greatly appreciated. Thanks.
louie7600 is offline   Reply With Quote
Old 07-27-2008, 07:36 PM   #2
Re: Passenger Side Power Window Not Working
sounds like a bad connections, i would pop the door cover off and check the wires, you can first though just pop out the door handle part where the controls are and check there~ see if when you push the button the power wire is getting power (with a power tester) then you can see if its the motor parts or the wires to the switch (and from the switch to the motor)
Passenger Side Headlight Goes out. GT_Miami 2005-2010 Mustang GT 12 07-07-2015 12:30 AM
power window not working rob913 1979-1995 Mustang GT 5 08-21-2010 11:28 AM
Rear Passenger power window motor failure drnelsen 1996-2004 Mustang GT 5 06-26-2009 08:08 PM
Passenger side power window motor replacement jaykay 1979-1995 Mustang GT 1 10-18-2008 02:40 PM
Passenger Window... Ibanezplayer272 1979-1995 Mustang GT 4 02-11-2006 01:48 PM
12:38 PM
