Might of hurt my car i think - Mustang Evolution
Old 09-25-2013, 01:55 AM   #1
Pickeringeric's Avatar
I have a 2013 prem conv I was going threw the settings and havent figure out the select shift yet on my automatic knob. When i reversed heard a bump kinda of werid to explain the sound drove home aright felt little slower then normal idk what to do.
Pickeringeric is offline   Reply With Quote
Old 09-25-2013, 06:54 AM   #2
bigmac3's Avatar
Don't know about the bump but the select shift is easy to use. If you put it in "S" and drive normal you will get brisker shifts and it will not go into 6th. If instead you hit the button either up or down it will go into manual mode. It will tell you on the panel what gear you are in and you can simply shift manually up or down. With it in manual mode you can shift into 6th. You can shift back into Drive at any time. If you want to go from manual back to Sport, you will have to shift back to Drive and then back to Sport. Piece o' cake.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
04:57 PM
