Line lock questions - Mustang Evolution
Old 09-28-2013, 08:37 PM   #1
Luna1994's Avatar
Region: Utah
Line lock questions
Iv been thinking about a line lock kit for my automatic 05 gt and I was curious how it works and what it does? And my e brake lines froze up and I had to cut them to get the car to move again and I just never got around to fixing them. Will I have to fix me e brake first?
Luna1994 is offline   Reply With Quote
Old 09-29-2013, 07:29 AM   #2
Ish416's Avatar
Line Lock just locks the front tires and not the rears.
Line Lock is a solenoid that is used inline on your front brakes. You flip a switch and hold the brakes and line lock will keep that amount of pressure on the front brakes and none on the rear, until you flip the switch back off. That allows people with manual transmissions to pull up, flip the line lock switch, hit the brakes, then use the clutch and gas pedal at the same time to do a burnout, without having to worry about using three pedals with two feet.
If you have an automatic and can powerbrake in your car, then you do not need line lock.
Old 09-29-2013, 07:44 AM   #3
1lowGT's Avatar
So with manual you gotta hit the brake then hit the switch and left off the Brahe than rev it and let loose?
Old 09-30-2013, 07:22 AM   #4
Coltonhess's Avatar
Is that dangerous to the car?
Coltonhess is offline   Reply With Quote
Old 09-30-2013, 10:06 AM   #5
No
---------- Post added at 11:06 AM ---------- Previous post was at 11:05 AM ----------
Basically yes. I have mine where I hold the switch in my hand. I just let go when i'm rolling out of the burnout.
I also preload the drivetrain slightly when launching and use it to keep from rolling over the line
Old 10-01-2013, 09:06 AM   #6
1lowGT's Avatar
What comes with the kit like off am is your switch custom?
Old 10-01-2013, 09:28 AM   #7
Whatever it says comes with it. I wired my switch to the cig lighter by the shifter. I plug my custom switch in there and am able to hold however I like.
But yeh, I made my own switch to my liking. Not a fan of extra things. Had it wired to the traction control button for a while and wasn't happy with the location.
Old 10-01-2013, 09:34 AM   #8
1lowGT's Avatar
I see. This isn't really something I need or want unless I had more power and went to the track every weekend.
09:55 AM
