trying to make my mustang louder - Mustang Evolution
Old 09-29-2013, 04:46 PM   #1
blackbeauty 2's Avatar
I have a 2010 mustang gt 4.6. I have installed borla s type kit. I like the borla sound but I am looking for more growl when just idling. Any ideas?
blackbeauty 2 is offline   Reply With Quote
Old 09-29-2013, 04:46 PM   #2
MidnightBlueGT's Avatar
Midpipe
Old 09-29-2013, 04:46 PM   #3
Doe_Rae_mi's Avatar
If you want it louder get loudmouths or Change midpipe
Old 09-29-2013, 04:51 PM   #4
I went to a performance shop and they said to add an x pipe. I installed the x pipe plus 44 flowmasters. A bit louder but not loud enough.
Old 09-29-2013, 05:16 PM   #5
Get an o/r h pipe, will make it louder and sound aggressive, then get some electric cutouts installed. Bam, open headers with the push of a button.
Make sure to keep the stock midpipe for when its time to smog.
Old 09-29-2013, 05:25 PM   #6
Would I have to dyno tune it if I change the midpipe?
Old 09-29-2013, 05:29 PM   #7
Nope. Not even flash tune. Only thing is if you go catless you'll throw a cel that a hand held tuner can turn off
Old 09-29-2013, 05:38 PM   #8
2 Stangz's Avatar
Region: Nevada
I have the same setup as you. Did you buy just the axle-backs or the whole cat-back system?
Old 09-29-2013, 05:52 PM   #9
The whole system
Old 09-29-2013, 06:05 PM   #10
2 Stangz's Avatar
Region: Nevada
Everyone knows ab removing the cats, plus I wouldn't recommend it, sooo...
How ab a custom tune with a higher RPM idle? I've heard ab other people doing it before.
Old 09-29-2013, 06:17 PM   #11
Tpost08's Avatar
Originally Posted by 2 Stangz View Post
Everyone knows ab removing the cats, plus I wouldn't recommend it, sooo... How ab a custom tune with a higher RPM idle? I've heard ab other people doing it before.
Why wouldn't you recommend it. He wants louder. Well it'll be louder also Adds more power.
Tpost08 is offline   Reply With Quote
Old 09-29-2013, 06:21 PM   #12
2 Stangz's Avatar
Region: Nevada
I've seen a ton of threads ab 'going catless' lately and it's just unappealing to me, all of the fines and inspection problems plus my stang is my DD... Not for me.
Old 09-29-2013, 06:26 PM   #13
Tpost08's Avatar
my STANG is my dd as well. I'm going o/r x as soon as I get the money. And as long as you want loud and and more hp. Then I think that it is for you. (Not you in general). O/r x-pipe would be ideal for the op because he wants louder.
Old 09-29-2013, 07:16 PM   #14
DallasStang77's Avatar
Completely get rid of the cat/midpipe and have an open exhaust
Old 09-29-2013, 07:30 PM   #15
Ok didnt see the catless is not an option post... I hear Flowmaster Outlaw is louder than most others.
Pipes Bomb makes one that's catback and its pretty raw and loud.
One thing is high flow cats.
There's only so much you can make an exhaust sound loud. And even idle without cats isn't really loud.
One option is Ghost Cam tune that gives you a cam type lop.
If all else fails and its still not loud enough... Add a system in your trunk and run a microphone to your exhaust and crank up the volume. I don't do sound systems ever in my car so I'm not good with specs etc... But maybe a 1000 watt amp would work wonders
Old 09-29-2013, 07:46 PM   #16
Luke02GTmustang's Avatar
I have a basanni catless X pipe and and a borla stinger cat back. amazing sound and it's pretty loud while cruising. nice sound at idle as well. expensive setup tho
Luke02GTmustang is offline   Reply With Quote
Old 09-29-2013, 08:11 PM   #17
Nasty5.0's Avatar
I have flow master outlaws and its very deep at idle and has a great rumble
Nasty5.0 is offline   Reply With Quote
Old 09-29-2013, 09:58 PM   #18
Yeah I think if idle exhaust note is what the OP is after he just needs a ghost cam tune.
Look into that cuz it does essentially partially apply throttle while your idling and adjusts timing so you sound like you have a crammed built motor... Even though you don't.
Old 09-29-2013, 10:57 PM   #19
Ucfknight's Avatar
Ghost cam tunes arent for 2010 and earlier GTs only the new 5.0s but I have a 2010 GT with flowmaster outlaws and o/r x pipe and its incredible!
Ucfknight is offline   Reply With Quote
Old 09-29-2013, 11:30 PM   #20
tc x 4's Avatar
You need HEADERS
Old 09-30-2013, 12:30 AM   #21
Damn missed the 2010 spec. Oh well... 1000 watt amp then?
Old 09-30-2013, 12:43 AM   #22
2 Stangz's Avatar
Region: Nevada
I'm with this guy. Subs add horsepower if fired towards the rear.
Old 09-30-2013, 01:49 PM   #23
KARgt13's Avatar
If he changes to high-flow cats, he'd be legal and could probably get away without tuning. Does anyone know how much louder high-flows would be over stock?
KARgt13 is offline   Reply With Quote
Old 09-30-2013, 02:09 PM   #24
2 Stangz's Avatar
Region: Nevada
Unless his cats go bad and need to be replaced, any aftermarket catalytic converter installation is illegal by federal law. Just FYI. I don't really see the point in "high flow" cats... Straight pipes or cats.
Old 09-30-2013, 04:20 PM   #25
Grabber Blue5.0's Avatar
High flow cats will still more than likely trigger a CEL so it would still need a tune.
Old 09-30-2013, 04:43 PM   #26
dobypaw3's Avatar
Flowmaster outlaws!
dobypaw3 is offline   Reply With Quote
Old 09-30-2013, 05:03 PM   #27
Redstang1's Avatar
Buy my pype bombs
Redstang1 is offline   Reply With Quote
Old 09-30-2013, 07:35 PM   #28
Tpost08's Avatar
2 stangz. What part of Louisiana are you from.
Old 10-01-2013, 09:08 PM   #29
Nasty5.0's Avatar
Originally Posted by dobypaw3 View Post
Flowmaster outlaws!
+1 fo sheezy
Old 10-02-2013, 12:45 AM   #30
Punch a hole in it and say you ran something over......
Old 10-02-2013, 02:52 AM   #31
2 Stangz's Avatar
Region: Nevada
That could actually work maybe.
Old 10-02-2013, 06:29 AM   #32
1st stang's Avatar
Mine is louder then hell but I have bbk tuned length headers cat deletes and 3" x-pipe and flowmaster outlaws
1st stang is offline   Reply With Quote
Old 10-04-2013, 09:09 PM   #33
Nasty5.0's Avatar
Any clips I would love to hear that
Old 10-04-2013, 10:30 PM   #34
Clips don't do them justice. Lookup a local shop or club. Never go by clop
04:54 PM
