Gears explanation - Mustang Evolution
Old 10-01-2013, 07:16 PM   #1
20143.7LV6's Avatar
Gears explanation
On this site I've heard lots of reference to "2.73" or 3.73" or "4.10." What do those numbers mean, are those ratios? Are the numbers measurements to a part or component?
I have a '14 V6 base automatic, so from what I gather I have 2.73? I hear recommendations to go up to 3.6 or 3.73? What is the difference? What will change in my car? Does it shift faster, accelerate better? Is this a reprogramming like a tune, or an actual part replacement?
Thanks in advance for anyone who can school me.
20143.7LV6 is offline   Reply With Quote
Old 10-01-2013, 07:22 PM   #2
MidnightBlueGT's Avatar
Theres answers to all in the search bar for gears I believe there may be a sticky as well and I know theres at least a link on a thread with all info on them where I learned. i just used the underrated search bar.
Old 10-01-2013, 07:34 PM   #3
Doe_Rae_mi's Avatar
It's a gear that replaces your rear end gear. It makes your car accelerate wayyyyyyy quicker. The bigger the gear the faster it will go 4:10 is a bigger gear than 3:73 or and your stock one
Old 10-01-2013, 07:44 PM   #4
In short:
Look under the rear of your car, there is a round shaped thing in the middle. Thats where your differential and gears are. The stock ratio for you is 2.73, which means the driveshaft turns 2.73 times for 1 wheel revolution. So a higher number like 3.73 means your driveshaft turns 3.73 times for 1 wheel revolution, meaning you will accelerate faster.
Theoretically, the higher the number the better the acceleration but lower top speed (not significantly reduced though).
Old 10-01-2013, 07:46 PM   #5
20143.7LV6's Avatar
Great explanation!!
Old 10-01-2013, 09:39 PM   #6
bucko's Avatar
Originally Posted by 20143.7LV6 View Post
Great explanation!!
Google is always your friend (and the great members of this site) for these types of questions!
Old 10-31-2013, 06:40 PM   #7
20143.7LV6's Avatar
Do I need a tune if I get new gears?
Old 10-31-2013, 07:53 PM   #8
JDM
JDM's Avatar
Yes, if you want your speedometer to be accurate.
JDM is offline   Reply With Quote
Old 11-01-2013, 08:38 AM   #9
Peterzinyou's Avatar
Get the gears and a tuner. You will not be disappointed
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 11-01-2013, 09:42 AM   #10
Dont necessarily NEED a tune. Just get a recalibration for the speedo to be correct. Or best to just get a tuner and change the axle ratio. Remember if your speedo is incorrect so are your readings from the odometer.
Old 11-01-2013, 10:05 AM   #11
For an auto you will need one because it relys on the rpms to shift which will be off if you get gears.
Old 11-01-2013, 10:20 AM   #12
True. Didnt see it said auto.
Old 11-01-2013, 10:27 AM   #13
Just wait until the anti-gear/ pro- torque converters come and chime in.
12:00 PM
