Error Code Deleting Options - Mustang Evolution
Old 10-02-2013, 09:38 PM   #1
04beautyGT's Avatar
I'm planning on getting a tune soon, but I'm cheap and want to get the chip vs the handheld, but the chip doesn't clear codes. I know the AeroForce Gauges do clear codes, but I'm just trying to see if there are other options. Does anyone else know how to clear codes. It's really annoying because it's just the emissions code, but not $100 worth.
Thanks for any input.
04beautyGT is offline   Reply With Quote
Old 10-02-2013, 09:40 PM   #2
yah buy one from walmart then return it hhaha easy
Mustangman705 is offline   Reply With Quote
Old 10-02-2013, 09:41 PM   #3
Venomouz831's Avatar
Disconnect you're batt for a bit then reconnect it. Did you fix the problem
)02 Gt, Founder of WE2G
Old 10-02-2013, 11:37 PM   #4
1slosix's Avatar
those two tricks will clear the code, but will not let it pass emissions at least in TN. They still have the saved memory bank that they will see when they plug it into their machine. My advice OP is to either pay for a proper tune to clear the code or fix the issue to make it go away on it's own.
carving corners like a boss
Old 10-02-2013, 11:41 PM   #5
04beautyGT's Avatar
I went to a shop and they reset it, but it came back on. I also did the battery thing, though I heard it could do damage
Sadie- '04 GT Auto- RMR#4837, 4-Point-SEXY
Old 10-03-2013, 12:00 AM   #6
So you have to get it fixed or it will keep on popping up. No it won't harm the car
Old 10-03-2013, 01:01 AM   #7
1slosix's Avatar
what is the light on for op?
Old 10-03-2013, 03:20 PM   #8
04beautyGT's Avatar
I don't remember the exact codes, but it was foe a small or large leak in the emissions system
Old 10-03-2013, 03:23 PM   #9
1slosix's Avatar
so um.... why don't you fix it. most evap leaks are faulty gas caps...or canister purge valve
11:12 AM
