D to S, and back? Is it safe? - Mustang Evolution
Old 10-03-2013, 06:56 PM   #1
Will it screw up the transmission to switch from D to S, or S to D, while driving? Is one safe and the other not? I haven't tried it.
Old 10-03-2013, 07:57 PM   #2
gtstyles2's Avatar
That shouldn't be a problem, I do it on my 13 Focus all the time
Old 10-03-2013, 08:11 PM   #3
So, it's safe to do while cruising at around highway speeds,ok. When you shift it, it stays in that gear when it goes to S, right, and what happens if you shift back to D if you were near redline in S?
Old 10-04-2013, 06:45 AM   #4
Clink's Avatar
I have no clue what this thread is about....
Old 10-04-2013, 06:53 AM   #5
It's not me, it's you.
primer2tone's Avatar
Automatics...
Old 10-04-2013, 07:34 AM   #6
OzzyLiriano's Avatar
Originally Posted by primer2tone View Post
Automatics...
Lmfaoooo
OzzyLiriano is offline   Reply With Quote
Old 10-04-2013, 07:38 AM   #7
RossLong's Avatar
The transmission and engine should both have failsafes of some for to prevent this from screwing it up. I know in most of these setups the transmission will delay to shift into gear until you let off the throttle and the rpms go down a little, at least that's what I have experienced in most vehicles I have driven with the manual shift auto transmissions.
RossLong is offline   Reply With Quote
Old 10-04-2013, 08:18 AM   #8
gtstyles2's Avatar
U should be good, just like in a manual when your driving down the road, when your going at different speeds u can use whatever gear u want... An auto knows what gear to put itself back in at a certain speed, u won't cause any damage, give it a shot
Old 10-04-2013, 02:42 PM   #9
I just found a video on the owner section of ford.com. It told me everything I wanted to know, or had questions about.
Old 10-04-2013, 08:14 PM   #10
I just used sportshift on a drive to my schools football game, I think I'm rarely going to use the D on my shifter now.
Old 10-06-2013, 09:09 AM   #11
Your focus has a computer controlled manual transmission, far different than the mustang transmission.
Old 10-06-2013, 09:37 AM   #12
9tee7pony's Avatar
What is sportshift? I am unfamiliar with this new fangled technology.
9tee7pony is offline   Reply With Quote
Old 10-06-2013, 09:44 AM   #13
Staytru06's Avatar
So I think your talking about shifting an automatic car with something like paddle shifters except it stays on the actual shifter. I have this on my bmw and I don't even have to take it out of D to S if I want to downshift the car. I can simply just click the paddle for "down shifting" and it drops a gear. I don't know how it is on mustangs but it does no damage to the bmw.
Staytru06 is offline   Reply With Quote
Old 10-06-2013, 09:48 AM   #14
gtstyles2's Avatar
O ok I figured that, it's like a dual clutch type trans on these... I thought an auto 13+ Mustang used the same
Old 10-06-2013, 10:04 AM   #15
Well I don't think going from D to S and back hurts the transmission... Only the MPG
Old 10-06-2013, 11:18 AM   #16
Nope. Shouldn't harm anything on the mustang, just wanted to point out the focus is a completely different design.
11:44 PM
