Advice on next mod - Mustang Evolution
Old 10-06-2013, 06:06 PM   #1
Luna1994's Avatar
Region: Utah
Advice on next mod
Ok so I have an 05 gt and iv got a good amount of mods
Cold air intake
Pro chamber mid pipe
Slp axelbacks
Throttle body spacer
Zex 100 shot
Bmr control arms
4.10 gears
Bama tune
Under drive pulleys
I'm looking for the next performce mod to accel harder and just be over all faster I want cams but that a little expenseve and advice?
Luna1994 is offline   Reply With Quote
Old 10-06-2013, 06:18 PM   #2
Lower control arms will help you launch better... Aluminum driveshaft will free up some rotational weight... Cams will add power.
There isn't really much you can do aside from actual engine work.
Old 10-06-2013, 06:25 PM   #3
Luna1994's Avatar
Region: Utah
Lower control arms will help you launch better... Aluminum driveshaft will free up some rotational weight... Cams will add power. There isn't really much you can do aside from actual engine work.
cams are what I wanna do next I'm thinking about it but install cost is what scares me
Old 10-06-2013, 06:26 PM   #4
Install it yourself, it's not that hard..
Terminator literally just finished installing cams himself a week ago.
Old 10-06-2013, 06:37 PM   #5
Luna1994's Avatar
Region: Utah
Install it yourself, it's not that hard.. Terminator literally just finished installing cams himself a week ago.
oh really? Maby I'll do that then
Old 10-06-2013, 08:06 PM   #6
There is a tool you will need to do it, but you can rent it from this place called Freedom Racing tools... Otherwise if you buy it, it will be a couple hundred $.
Old 10-06-2013, 08:19 PM   #7
Luna1994's Avatar
Region: Utah
what tool?
Old 10-07-2013, 08:02 AM   #8
You will also need to degree any cams you buy, regardless of what you hear about keeping the sprockets aligned or "line up the dots" or whatever. If you don't degree them they WILL be off. If you buy cams from MHS they have the option for a degree service where they're done for you. But at any rate, prepare thy anus for the cost of 4 modular cams.
Old 10-07-2013, 08:44 AM   #9
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Cold air intake
Slp axelbacks
Zex 100 shot
Bmr control arms
4.10 gears
Bama tune
Under drive pulleys
It sounds like you have a great build so far! How much power are you making on Spray and have you taken your Mustang to the track? I'd love to hear the results!
You definitely have all the basic bolts on done and then some! It looks like you've decided to do cams next, that's a great mod on the 3V's. The install on a Mustang is pretty difficult and I would recommend professional installation if you haven't attempted a job to this extent before! Cams will pick up a ton of power up top on your car.
You may also want to look into a 1-Piece driveshaft. Saving weight is always important, especially off of rotating mass! You'll pick up 3 tenths in the quarter mile from switching out the driveshaft and it's much stronger.
I hope this helps. Let me know if you have any questions or need some assistance!
-Dan
Old 10-07-2013, 07:25 PM   #10
Luna1994's Avatar
Region: Utah
Originally Posted by AMDanBailer View Post
It sounds like you have a great build so far! How much power are you making on Spray and have you taken your Mustang to the track? I'd love to hear the results! You definitely have all the basic bolts on done and then some! It looks like you've decided to do cams next, that's a great mod on the 3V's. The install on a Mustang is pretty difficult and I would recommend professional installation if you haven't attempted a job to this extent before! Cams will pick up a ton of power up top on your car. You may also want to look into a 1-Piece driveshaft. Saving weight is always important, especially off of rotating mass! You'll pick up 3 tenths in the quarter mile from switching out the driveshaft and it's much stronger. I hope this helps. Let me know if you have any questions or need some assistance! -Dan
what cams are ganna give me the best hp gains I heard the Detroit rockers are great
Old 10-07-2013, 08:08 PM   #11
MMR NA cams have good reviews and even the Ford Hot cams are good. A guy around the corner from me has cams in his 05-09 and it sounds badass. Problem is he drives like a complete ******-canoe and has woken me up multiple times at 3 in the morning doing like 65mph through the 25mph zone in our neighborhood so I don't really want to flag him down and talk to him except to tell him to slow the ufck down.
02:59 AM
