96-98 PI vs 99-04 - Mustang Evolution
Old 10-08-2013, 12:00 PM   #1
calebnaasko's Avatar
96-98 PI vs 99-04
Stupid question cuz I think I know the answer.
Will a 96-98 GT with PI swapped heads and intake beat a 99-04 gt?
Also does anyone have a link to a PI swap write up?
Thanks!
calebnaasko is offline   Reply With Quote
Old 10-08-2013, 12:06 PM   #2
twotone01's Avatar
Originally Posted by calebnaasko View Post
Stupid question cuz I think I know the answer. Will a 96-98 GT with PI swapped heads and intake beat a 99-04 gt? Also does anyone have a link to a PI swap write up? Thanks!
That'll be up to the driver haha after the swap it's the same engine
twotone01 is offline   Reply With Quote
Old 10-08-2013, 12:33 PM   #3
1996mustang's Avatar
Wrong.....96-98 with pi heads swap will push out a tid bit more than a 99-04 due to the raise in compression roughly 10.54:1 so instead of 260 more like 272hp or 275hp to the flywheel. Add intake and well if the 96-98 is a crappy driver then he/she should have a half car atleast on the track considering if the 99-04 is stock
Old 10-08-2013, 12:36 PM   #4
Yeah I thought it would have more power cuz of the higher compression. Just checking!
Good Info man
Old 10-08-2013, 12:43 PM   #5
1lowGT's Avatar
Tranny? Auto manual?
Old 10-08-2013, 12:57 PM   #6
twotone01's Avatar
Ohh ok I didn't know it raised compression a little bit, I always thought it was the same because I had a friend that had a 97 pi swap and he wouldn't be able to keep up with my other buddies 04 with an intake and exhaust
Maybe my buddy with the 97 just was a bad driver lol
Old 10-08-2013, 01:01 PM   #7
Sadly auto
Old 10-08-2013, 01:08 PM   #8
It truly depends on alot when you look into it. A 96-98 will get a bump in compression and produce a tad more power. Another factor is tranny whether its manual or auto it does make a difference in actual power to the ground. Manual will make more due to less drivetrain loss however an automatic will shift exact at all times. Still auto weighs more and another thing is if the vehicle is a coupe or a vert. Verts are heavier leading towards the power to weight ratio being greater on a manual coupe rather than a auto vert. It also depends on what modes the cars had. Or ...... crappy driver lol. Alot to consider into y someone could win or lose in track races (im saying track so i dont say street)
---------- Post added at 03:05 PM ---------- Previous post was at 03:04 PM ----------
Sadly auto
Auto isnt a bad thing. With gears an auto will eat a manual hands down. Autos are king when it comes to a straight line.
---------- Post added at 03:08 PM ---------- Previous post was at 03:05 PM ----------
Sadly auto
Old 10-08-2013, 01:09 PM   #9
1lowGT's Avatar
Exactly
Old 10-08-2013, 01:32 PM   #10
twotone01's Avatar
It truly depends on alot when you look into it. A 96-98 will get a bump in compression and produce a tad more power. Another factor is tranny whether its manual or auto it does make a difference in actual power to the ground. Manual will make more due to less drivetrain loss however an automatic will shift exact at all times. Still auto weighs more and another thing is if the vehicle is a coupe or a vert. Verts are heavier leading towards the power to weight ratio being greater on a manual coupe rather than a auto vert. It also depends on what modes the cars had. Or ...... crappy driver lol. Alot to consider into y someone could win or lose in track races (im saying track so i dont say street) ---------- Post added at 03:05 PM ---------- Previous post was at 03:04 PM ---------- Auto isnt a bad thing. With gears an auto will eat a manual hands down. Autos are king when it comes to a straight line. ---------- Post added at 03:08 PM ---------- Previous post was at 03:05 PM ---------- Auto isnt a bad thing. With gears an auto will eat a manual hands down. Autos are king when it comes to a straight line.
Yeah that's true the weight does play a roll as well a tranny but both were 5 speed coupes I'm just assuming my buddy was not as a good as driver as my friend in the 04 haha but yeah it was at a set up event they went to Why does it raise the compression? Or should I ask how? I'm planning a build for my stang because it's got 177k on it and I'm debating do a full build or like just top end junk yard build
I've got an 03
Old 10-08-2013, 01:34 PM   #11
1lowGT's Avatar
Well you could start now with a junkyard build. Or build a fresh one.
Old 10-08-2013, 01:40 PM   #12
twotone01's Avatar
I was thinkin that route because I just want it to last till I get the money for my mach 1
I found an 03 motor with just under 80k for 800 bucks
I don't know if that's a good price haha but I can get a reman motor from work but that'll be expensive and idk if I get my discount
Old 10-08-2013, 03:18 PM   #13
Well the 96-98 raise compression cause when u swap the heads to 99-04 heads the deck height i believe if i remember gets smaller. For your 03 you already have pi heads and intake. The way to raise your compression is pistons or go back and use a 96-98 block with your current heads. Your years is when ford decided the stang needed a little pep to its step
Old 10-08-2013, 03:48 PM   #14
twotone01's Avatar
Ohh ok makes sense, maybe ill buy a 96-98 motor and get the PI kit and put it together at work with some buddies, It'll be easier to do here than at home since ill have every ford tool I'd need lol
The PI heads from AM are pretty cheap, I'm surprised how much they are. Ill look into getting heads from work also and maybe reman heads would be cheaper
Old 10-08-2013, 03:57 PM   #15
Get a Bullitt intake and you will be making roughly the same power, with an amazing power curve.
Old 10-08-2013, 04:03 PM   #16
Twotone you already have pi heads. Hes right a bullit intake would do the same hp as a 96 with pi swap. If you wanna gain some power i would port and polish heads change valve springs and retainers to atleast run stage 2 cams. The heads on am im sure are the exact same as yours with maybe a little porting to make it flow well. You could do bolt ons with gears as well as tuner. But heed a warning while yes my year makes more power cause of a compression raise it doesnt help when you wanna push more boost on higher compression. Things tend to go bump in the night then. Your motor is set nicely to just add bolt ons with a power adder i.e. turbo or supercharger and tou will do fine. With mine and a pi swap im gonna eventually have to lower my compression to push as much boost as you could
Old 10-08-2013, 04:04 PM   #17
twotone01's Avatar
I'd love to but they're so dang expensive haha
Old 10-08-2013, 04:09 PM   #18
You can always port the stock intake
Old 10-08-2013, 04:15 PM   #19
twotone01's Avatar
I know I have the pi heads and the pink injectors and Blahblah but appreciate the info 👍 haha I was thinking about buying the new pi ones to add to the older block, but a power adder is not in mind right now. I'd like a nice peppy DD, I just never knew that the deck height was reduced when doing the pi swap. As for the stage two cams, I'd love it but gotta keep it Cali legal now. Moved to far from our buddy to get it "smogged" haha there's so many options to go with when it comes to building a motor, and I just learned more about the PI swap for the 96-98 so it got me thinking haha
---------- Post added at 03:15 PM ---------- Previous post was at 03:14 PM ----------
very true haha but I'm afraid to do much to my current engine because if it blows before I got the cash to rebuild/buy another I'm screwed haha
Old 10-08-2013, 04:17 PM   #20
I know I have the pi heads and the pink injectors and Blahblah but appreciate the info ddc4d haha I was thinking about buying the new pi ones to add to the older block, but a power adder is not in mind right now. I'd like a nice peppy DD, I just never knew that the deck height was reduced when doing the pi swap. As for the stage two cams, I'd love it but gotta keep it Cali legal now. Moved to far from our buddy to get it "smogged" haha there's so many options to go with when it comes to building a motor, and I just learned more about the PI swap for the 96-98 so it got me thinking haha
There are cams legal in Cali, just find out the name of them and then when it's time for smog tell them it's those ones. They aren't going to tear your motor apart.
Old 10-08-2013, 04:20 PM   #21
I want your pink injectors lol. Yes soccers right a stage one is perfectly fine research it you will see cali legal cams.
Old 10-08-2013, 04:21 PM   #22
Most cams will still let you pass the sniff test. It's the stupid visual testing and CARB stickers everything needs that fails most people.
05:03 AM
