Diff fluid - Mustang Evolution
Old 10-18-2013, 06:33 PM   #1
Screaming Mach's Avatar
Diff fluid
I'm changing the fluid in the rear of my 04 mach I was told to use 75w90 is that right? And how much do I need ? I use royal purple thanks
Screaming Mach is offline   Reply With Quote
Old 10-19-2013, 11:27 AM   #2
twk
twk's Avatar
I didn't check your profile for what diff you have, but I put a FR 8.8" a few months ago on an '09 v6. It has a sticker on it that says 75w 140 Synthetic Lube. I hope that helps.
twk is offline   Reply With Quote
Old 10-19-2013, 03:56 PM   #3
twk
twk's Avatar
Ah, it seems whoever told you 75w90 is likely correct. I just happen to see this:
Mustang 8.8" Rear Differential Fluid & Seal Kit (86-04) - LatemodelRestoration.com
It's an oil change kit for your car with the 75w90 oil.
Old 10-19-2013, 06:44 PM   #4
Thank you!!!!!
Old 10-19-2013, 07:16 PM   #5
sinister07's Avatar
Be sure to get a tube of friction modifier, or you will damage the TracLock.
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 10-19-2013, 10:52 PM   #6
sinister07's Avatar
Oops, I see that the above-listed kit includes the friction modifier.... all good!
2003 Mach 1
Old 10-19-2013, 11:01 PM   #7
Thanks!!!
04:36 PM
