Speed Limit - Mustang Evolution
Old 10-20-2013, 10:36 AM   #1
Stampede305's Avatar
Speed Limit
I slowly started to let my foot drop and as the speedometer hit 115mph it wouldn't go past that, I was in 4th gear so I shifted to 5th and nothing the rpm's were not even maxed out. I feel like this might have to do with the ecu, if so how can I fix this?
Thanks in advance guys!
Stampede305 is offline   Reply With Quote
Old 10-20-2013, 10:41 AM   #2
Kona Mike's Avatar
Governor. It's on there so your driveshaft doesn't end up poking through you floor board.
Kona Mike is offline   Reply With Quote
Old 10-20-2013, 10:44 AM   #3
that's why^ lol
Old 10-20-2013, 10:51 AM   #4
1slosix's Avatar
three reasons.
1. driveshaft issue
2. govenor
3. because there's no reason you need to go faster
also i had to edit your post a bit or i'd have to close your thread all together. welcome
carving corners like a boss
Old 10-20-2013, 10:51 AM   #5
Black on Boss's Avatar
A tune will remove it but it's not recommended. I had my 3.7 over 130 before on a track but that was before I knew of the issues with the shaft.
Old 10-20-2013, 02:34 PM   #6
So basically if I tune it to remove the block it will start to mess with my drive shaft?
Old 10-20-2013, 02:51 PM   #7
Tyoung68's Avatar
Your drive shaft will blow apart
Old 10-20-2013, 03:06 PM   #8
Old 10-20-2013, 03:32 PM   #9
Yea the driveshaft is a very crappy design on the V6 models, if you go 130+ you will risk it literally snapping.
Old 10-20-2013, 04:10 PM   #10
technically for a normal driver its perfectly fine but people like us who live off of this should've had an optional driveshaft that can handle more lol
Old 10-20-2013, 08:37 PM   #11
Ahhh that's lame! Time for a new drive shaft! Haha
---------- Post added at 09:37 PM ---------- Previous post was at 09:37 PM ----------
That video is crazy!
02:21 PM
