tune up - Mustang Evolution
Old 10-26-2013, 08:42 AM   #1
Luke02GTmustang's Avatar
tune up
what kind of tune up do you guys recommend if my 02 is running pretty rich?
Luke02GTmustang is offline   Reply With Quote
Old 10-26-2013, 09:46 AM   #2
1lowGT's Avatar
Getting rid of the stock tune.
Old 10-26-2013, 10:38 AM   #3
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
You can adjust the A/F ratio with a handheld tuner like SCT.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 10-26-2013, 10:44 AM   #4
Terminator's Avatar
If i do that will it mess with the bama tune i have now ?
Terminator is offline   Reply With Quote
Old 10-26-2013, 11:38 AM   #5
I've been doing exactly that for the last few days. I have a BAMA 91 octane performance tune that was pinging like crazy. So I started pulling timing by 1 degree then drove it to see if it helped. I pulled a total of 4 degrees timing, and now it is running great with zero pinging.
Old 10-26-2013, 12:41 PM   #6
Terminator's Avatar
I will try it than keep running lean even with them revising my tunes it all started once i went tuned car
Old 10-26-2013, 03:18 PM   #7
Yeah, my BAMA tune sure left a lot to be desired. But I'm glad you can adjust your tune with the handheld. It must be hard to get tunes right if you don't have the car in front of you, but my tune was pretty far off.
Old 10-26-2013, 03:21 PM   #8
You do have a supercharger and cams lol.... Honestly you should have a dyno tune.
Old 10-26-2013, 04:06 PM   #9
Terminator's Avatar
Yea but even from the start its been the same
Old 10-26-2013, 08:44 PM   #10
well see my car is running really rich and the guy at mienekie suggested a full fuel injection and throttle body cleaning for $300
Old 10-26-2013, 09:06 PM   #11
Well of course they did. That's how they make money. Go buy a can of carb cleaner and a can of seafoam. Pour half the seafoam in gas tank. Take off tb and spray insides clean with carb cleaner. Just saved you $280.
How do you know you are running rich? If you have a tune datalog and send your tuner the logs.
Old 10-26-2013, 10:12 PM   #12
Well of course they did. That's how they make money. Go buy a can of carb cleaner and a can of seafoam. Pour half the seafoam in gas tank. Take off tb and spray insides clean with carb cleaner. Just saved you $280. How do you know you are running rich? If you have a tune datalog and send your tuner the logs.
good thinking. exhaust blows blue smoke and the inside of my exhaust is black. 21.5 lb injectors stock fuel system.
04:16 AM
