Catalytic converter problem - Mustang Evolution
Old 10-31-2013, 11:51 AM   #1
cleanmach1's Avatar
I know that my passenger side catalytic converter is having some kind of problem, I'm hearing random rattling noises from under the car and smoke is coming out of the passenger side tail pipe even when the car is off. How long can I drive the car before there will start to be danger to the engine?
cleanmach1 is offline   Reply With Quote
Old 10-31-2013, 01:47 PM   #2
Do you have true dual exhaust that doesn't connect at the mid pipe?
Old 10-31-2013, 01:48 PM   #3
cleanmach1's Avatar
No it's a bassani catted xpipe
Old 10-31-2013, 02:02 PM   #4
Well if you had a problem with either cat then it would reflect both sides of your exhaust system, because the system is balanced via the x-pipe. Provided you have no CEL and the smoke isn't colored. I'd be almost 100% willing to be you have a broken hanger or something and something burning out of one of your mufflers than got inside of it.
Old 10-31-2013, 02:07 PM   #5
cleanmach1's Avatar
Well if you had a problem with either cat then it would reflect both sides of your exhaust system, because the system is balanced via the x-pipe. Provided you have no CEL and the smoke isn't colored. I'd be almost 100% willing to be you have a broken hanger or something an something burning out of one of your mufflers than got inside of it.
No it's the cat because i took it to a shop and put it on the lift and there is nothing loose or anything and there aren't any leaks. So I'm assuming the noises I was hearing was the loose material in the cat itself that has been blown out the tail pipes by this point. My only question is Will it hurt my car to run it with a faulty cat untill I have time to replace it with an offroad h pipe
Old 10-31-2013, 02:23 PM   #6
Site Sponsor
Sponsor
AMWill's Avatar
If you blew out your cat, then there shouldn't be anything to worry about as far as your engine goes. This is assuming the catalytic converter is not clogged, but instead truly blown out. However, I would be concerned about catalytic convertor material traveling through the exhaust and getting stock in your mufflers. I've seen quite a few mufflers that were somewhat clogged because of this.
I would get this taken care of ASAP, since no good can come from it. To answer your question, there's nothing that should harm the engine.
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 10-31-2013, 02:29 PM   #7
cleanmach1's Avatar
Shane
Thanks I have a flowmaster outlaw series mufflers just welded on 2 days ago but Do you think it would affect those even though they are straight through mufflers?
Old 10-31-2013, 02:54 PM   #8
Site Sponsor
Sponsor
AMWill's Avatar
It's not likely since they're straight through mufflers. The worst that can happen with a muffler like that is small pieces getting stuck in the baffling ports on the sides. Which is nothing that will reduce flow or make a audible vibration. You should be okay!
Shane
Old 10-31-2013, 04:21 PM   #9
twk
twk's Avatar
I'm a bit confused here. Your cats are forward of the x-pipe, right?
Like ZLwhat said, to paraphrase,
If either single cat was the cause of the smoke, the smoke would come out of both tail pipes. It would seem to me something is inside the right hand side exhaust, behind the x-pipe.
If you just had mufflers put on, maybe there was something inside the right hand side muffler and it finally decided to burn. This doesn't explain the noise you hear, but you may have two problems. The rattle, and the smoke.
twk is offline   Reply With Quote
Old 11-01-2013, 10:01 PM   #10
cleanmach1's Avatar
ya thats what im thinking that maybe something went to the passenger side muffler and got caught, thus creating a smoke to come out of only one tail pipe. but regardless the rattling noise is gone so i guess i just need to have the midpipe swapped out before the next inspection lol
05:59 AM
