140k miles & oil - Mustang Evolution
Old 11-10-2013, 07:23 PM   #1
140k miles & oil
so I picked up my 05 GT with 140k and I've always heard don't go synthetic with a high mileage car. Atleast for the last 90-100k miles I'm pretty sure it's just had 5w30 Penzoil in it. Thoughts, opinions, & suggestions welcomed. I ran RP 5w30 in my sixxer & if I have to stick with conventional oil the main thing I'm gonna miss is how long I went between changes.
Old 11-10-2013, 07:55 PM   #2
Just go synthetic.
Old 11-10-2013, 07:56 PM   #3
Won't mess anything up?
Old 11-10-2013, 07:59 PM   #4
You will be fine. We took our truck with 145k on it that only ever had dinosaur oil and put synthetic in it. Never had any issues. When i change the oil in the Mustang, that has about 142k on it, i'm putting in synthetic.
Old 11-10-2013, 08:01 PM   #5
I've got some miles to decide
Old 11-10-2013, 08:10 PM   #6
MidnightBlueGT's Avatar
Good ol synthetic
Old 11-10-2013, 10:23 PM   #7
Motorcraft blend oil with a Motorcraft filter. Cheap, effective, great oil, available everywhere.
Old 11-10-2013, 10:24 PM   #8
It's good tho even with high miles?
Old 11-10-2013, 10:25 PM   #9
I go to firestone. They have semi synthetic for like 18 bucks. And I give them a K&N filter to use. Its a great deal
ManBearPigBalls is offline   Reply With Quote
Old 11-10-2013, 10:31 PM   #10
What brand oil? Check your receipt, if it says "bulk oil" then it could be anything. Also you can get the Motorcraft blend in 5 qt jugs for $18 at wal mart. Throw in an extra qt at $3 and $3 for a Motorcraft filter. Under $25 for an oil change with a known good oil and you know you are doing it right vs having some minimum wage worker doing it.
Old 11-11-2013, 06:00 AM   #11
I have a few cars when they got up in mileage I switched to the hi mileage stuff I try to do a oil change every 3000 mileage now I using a 2013 V6 which I love , I use only synthetic in newer cars using what the manufacturer calls for 5-20 or whatever they say, I'm using the Fram Gold filter I like Fram as there easy to get a grip on
jon paris is offline   Reply With Quote
Old 11-11-2013, 06:18 AM   #12
If you have issues then its not going to be caused by an oil it'll be because something is on the way out. If it runs great then change it out with some Motorcraft or really any oil of your choosing. And don't wait to do the oil, even the if the PO says it just got done. Oil, trans fluid, differential fluid and the PS fluid if it looks dirty. Coolant drain/fill is good practice too.
Old 11-11-2013, 09:30 AM   #13
Well I just put Penzoil in it cause I was weary of changing but I believe in motorcraft that's what I use in my gf 500 w/130k but hers uses a quart between changes
06:07 PM
