4.6 to ls1 swap - Mustang Evolution
Old 11-14-2013, 07:49 PM   #1
Mxwilly387's Avatar
4.6 to ls1 swap
I hate to ask this (because I'm a diehard mustang person) but I threw a rod in my 2003 mach1 4v 4.6 and came across a ls1 with a trans from a friend for VERY cheap. Would anybody have any ideas on what all I would need for this swap? Any input is takin seriously. Thanks!
Mxwilly387 is offline   Reply With Quote
Old 11-14-2013, 08:40 PM   #2
Omg DO NOT DO THIS!!
Those swaps are for crapped out fox body's
DO NOT RUIN A MACH 1 COLLECTORS CAR WITH THIS ABOMINATION!
KoolPwny is offline   Reply With Quote
Old 11-14-2013, 08:43 PM   #3
Newline's Avatar
Need a k member and some exhaust - get everything you can for the ls1 and budget + 20% of whatever you think you'll need- and to hell with purists and the like- nothin is to precious to cut up
Newline is offline   Reply With Quote
Old 11-14-2013, 08:58 PM   #4
Mxwilly387's Avatar
I seen something online saying all you need for putting it in was the motor mounts off of cobra block and should bolt right up to stock k member. But was hoping to find someone who has done this or someone who knows about them. I'm going to look into that, thanks for the input bud
Old 11-14-2013, 09:02 PM   #5
I am by NO MEANS a purist. I LOVE ls1s as much as the next guy. I appreciate a fine build regardless of brands.
Old 11-14-2013, 09:10 PM   #6
Screaming Mach's Avatar
No bro not the mach
Screaming Mach is offline   Reply With Quote
Old 11-14-2013, 10:00 PM   #7
I thought about it for the Bullitt, then i decided to just make it a show car.
Old 11-14-2013, 11:33 PM   #8
Mxwilly387's Avatar
I'm going to be honest I just don't have the money to fix it with the same motor, that's going to cost a lot with the 4V modular motor. I'm getting the ls and trans for 600 bucks. Id rather do it the stock way but it be kinda cool to have a unique Mach I can say I built myself.
Old 11-14-2013, 11:37 PM   #9
this I completely understand. Sorry to be an ***. Mod motors are expensive
Old 11-14-2013, 11:51 PM   #10
Mxwilly387's Avatar
it's all good just figured I'd say why I couldn't do it the way I really wanted to
Old 11-15-2013, 05:51 AM   #11
Ish416's Avatar
Apparently this seems like a pretty simple swap.
According to the guys on LS1tech all you need is a K member and mounts or just mounts. Then a transmission crossmember and wiring. Also need a custom drive shaft.
This is actually a recent thread - 2000 mustang gt ls1 swap - LS1TECH
Here is for the AJE stuff - AJE Racing - Anthony Jones Engineering - Racing Suspensions
Old 11-15-2013, 08:03 AM   #12
Throw a cam on your LSx and you'll be faster than a 4v anyways
Old 11-15-2013, 08:45 AM   #13
Mxwilly387's Avatar
Originally Posted by Ish416 View Post
Apparently this seems like a pretty simple swap. According to the guys on LS1tech all you need is a K member and mounts or just mounts. Then a transmission crossmember and wiring. Also need a custom drive shaft. This is actually a recent thread - 2000 mustang gt ls1 swap - LS1TECH Here is for the AJE stuff - AJE Racing - Anthony Jones Engineering - Racing Suspensions
Thanks man I apretiate the info.
Old 11-15-2013, 08:58 AM   #14
Ish416's Avatar
I think even a stock LSx wouldn't have much issue taking out a 4v.
Cam it and run down some Terminators/5.0/Bosses. Cam and spray, run down GT500's.
In all honesty.. if you want a street/strip bruiser, go with an MS3 (Magic Stick V3) cam and a good tune. 400+whp, awesome sound and still pull down high 20's mpg on the highway/interstate.
For cams and things, go to Texas Speed Camshaft Package w/ Dual Valve Spring Kit
Also, depending on the year of your LSx an LS6 or Fast 102 intake can do wonders.
Old 11-15-2013, 06:49 PM   #15
LS6 heads and your choice of can with an LSX intake and your set
Old 11-15-2013, 07:48 PM   #16
Hmm like a tin can or an aluminum can? Which has better performance?
Old 11-15-2013, 09:16 PM   #17
Cam* lol
Old 11-15-2013, 10:29 PM   #18
Cam* lol
I know I just like talking **** hahaha
Old 11-15-2013, 10:36 PM   #19
shsfresh87's Avatar
Region: West Virgina
You just lost your Stang card
shsfresh87 is offline   Reply With Quote
Old 11-16-2013, 01:26 AM   #20
+1. Hey I got an idea. Lets **** up a special edition mustang to celebrate the 50th anniversary!
87fiveoh is offline   Reply With Quote
Old 11-16-2013, 01:49 AM   #21
hey how about you buy him a forged rotating assembly so you stfu??
Don't want to?? Boo hoo jump off a cliff
Old 11-16-2013, 04:00 AM   #22
EastTNMustang's Avatar
Or...sell the LS and trans, then purchase a Coyote for your Mustang. Around here the drift crowd are snatching up the LS for at least 2k and that's just the motor...add another $1500 minimum for a 5 or 6 speed manual transmission.
EastTNMustang is offline   Reply With Quote
Old 11-16-2013, 05:33 AM   #23
Mxwilly387's Avatar
Yeah I don't get people on here I asked got help if you don't have any then don't post anything, I wouldn't have a Mach 1 if I wasn't a mustang guy, not everybody is fortunate enough to fix the stuff back stock, which with these motors I'll be spending atleast 5-7k the ls motor stock has over 100hp more then the 4.6 anyway. Why not go with more power for less money? Thought that's the point of this anyway for me.
Old 11-16-2013, 05:48 AM   #24
If you do it what are you going to do about the shaker are you going to fabricate some mounts or just get rid of it ?
Old 11-16-2013, 07:27 AM   #25
Mxwilly387's Avatar
Not sure on that part yet, fabricating something up won't be hard (it's basically what I do for a living) but thought about a cowl hood. I'll post some pics up once I start and finish the motor job.
Old 11-16-2013, 07:34 AM   #26
alrefire's Avatar
The cheapest I've seen a coyote go was for 3k minus the trans
Old 11-16-2013, 08:03 AM   #27
taylor98gt's Avatar
I've thought about doing this to my 98 gt. There's always gonna be Poople hating on doing it but they can kiss your *** when your beating their 3000 dollar set up with your cam only LS mustang . And tired2v on ls1tech has done the swap and done a complete write up on it. Seems like a fairly simple swap honestly.
taylor98gt is offline   Reply With Quote
Old 11-16-2013, 08:07 AM   #28
Kona Mike's Avatar
last I checked they don't give away motors. If you are concerned sponsor his build.
Kona Mike is offline   Reply With Quote
Old 11-16-2013, 08:15 AM   #29
Yes I'm not a big fan of doing it but if he got a good deal on a ls motor an can't afford a rebuild on a 4v (there not cheap) its his choice because its his car but if I was him I would but the old motor away and not sell it In case 1 day he wants to but it back in OP I hope it turns out great for you and yes post some pics from start to finish pls
Old 11-16-2013, 08:44 AM   #30
Newline's Avatar
Damn-... Lots of hatin on this post..
I'll say one thing-
I build cars for a living- I have seen and heard some really strange things about cars and motors being swapped- an lsx in a Mach 1 is a cool idea regardless of being a ford or chevy or dodge or whatever guy... The 32 ford coupe came with a flathead making a whopping 75 horse with a lot of time and effort put into it- the first guy who put a sbc into one was probably talked to much the same way you are right now- forget everybody else and build YOUR car- good luck and have fun!
Old 11-16-2013, 08:45 AM   #31
Mxwilly387's Avatar
Thanks for the positive feedback everybody, it's the motor and trans for 600 bucks I can't beat the deal, has 60k miles on it so why not. My block has a whole in it now so it's worthless. I'd rather fix it but dont have the money for the block, rotating assembly and possibly new heads. Lol ford likes those motors with the price of them
Old 11-16-2013, 08:52 AM   #32
Newline's Avatar
Hey man if you're near jersey let me know - I may have some hands to Lend and parts
Old 11-16-2013, 09:08 AM   #33
Mxwilly387's Avatar
Thanks man but I live in texas lol
Old 11-16-2013, 09:59 AM   #34
Butch's Avatar
Region: New Mexico
Rod job ÷]„„ how did it happen¿
---------- Post added at 09:59 AM ---------- Previous post was at 09:55 AM ----------
Whete in the world did did you find that¿
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 11-16-2013, 09:59 AM   #35
xhgwx's Avatar
Wait wait....
Question....
How did you snap a rod?
What are your mods?
xhgwx is offline   Reply With Quote
02:20 PM
