Mustang Fuel System & MPG - Mustang Evolution
Old 11-17-2013, 08:28 PM   #1
Can getting 42 lbs injectors and an svt pump (or any upgraded one) WITH A TUNE get me better gas mileage with 4.10 gears?
Don't flame me because I honestly don't know.
The reason I think is so it wouldn't work as close to full duty cycle.
Anyone?
KoolPwny is offline   Reply With Quote
Old 11-17-2013, 08:32 PM   #2
Anyone?
No larger injectors require more fuel and a larger capacity fuel pump will not allow you to utilize any other benefit other than more fuel being delivered to the rails. Your best bet for better gas mileage is to get a more highway friendly gear ratio and a tune up.
Old 11-17-2013, 08:35 PM   #3
Ahh I see thanks.
I was just trying to explore other options.
I love my gears too much and won't ever go back lol. But thanks for the quick answer ZL
Old 11-18-2013, 02:00 AM   #4
Ahh I see thanks.
You could try running taller tires in the rear also but that will make your speedo and odometer off even more unless it is digital and you can change it in a tune. A taller rear tire will lower your rpms on the highway.
Old 11-20-2013, 01:17 PM   #5
Anything after 93 was a digital speedo and easy enough to change with a speedcal box or a tune. Easy way to save gas is slow the hell down. I do 70mph with my 3.73s in my 98GT and routinely get over 20mpg hand calculated.
And being a 2004 you are running rich right from the factory. The computer is tuned for 19s but those run at 90% duty cycle on the PI 2V so in the last few years they went to 21s and never changed the tune. Get a good tune and it'll lean out a little and save you some gas that way.
However, you have a sports car, if you are THAT concerend about fuel economy get a beater to drive to work. A mid 90s Civic is $1k and gets near 40mpg.
05:44 PM
