4.6 vs 5.0 - Mustang Evolution
Old 11-18-2013, 01:02 PM   #1
4.6 vs 5.0
Ok here's a thread that you 4.6 vs 5.0 guys can go at each other's throats all day long without derailing other threads.
I'll start
2v rules the world
GO!
KoolPwny is offline   Reply With Quote
Old 11-18-2013, 01:04 PM   #2
LS>4.6
Old 11-18-2013, 01:05 PM   #3
MidnightBlueGT's Avatar
Boosted built 2v>5.0 all day
Old 11-18-2013, 01:10 PM   #4
Boosted/built 5.0>boosted/built 4.6
Old 11-18-2013, 01:10 PM   #5
mystang50's Avatar
nitrous/cam/stall/gears/bolt on 5.0...come at me bro!
Old 11-18-2013, 01:12 PM   #6
Nitrous/cam/stall/gears/twin turbo 5.0.... I just did bro
Old 11-18-2013, 01:29 PM   #7
gladiatoro's Avatar
2005-2010 3V Mustang Short Block Motor - JDM Engineering
1000 HP 4.6 L plus BLOWER / 2000HP = bye bye 5.0 plus BLOWER
gladiatoro is offline   Reply With Quote
Old 11-18-2013, 01:29 PM   #8
. A lot more money than the 2v though most money usually wins.
Old 11-18-2013, 02:42 PM   #9
2000HP with no head work and a supercharger? I tell you what. If you buy that short block and make that happen without extreme head modifications I will reimburse you the money you spent.
Old 11-18-2013, 03:03 PM   #10
I would rather build a $5000 2v than start with a $30000 coyote. That automatically makes a 2v cheaper to build to get to almost the same powet
---------- Post added at 02:03 PM ---------- Previous post was at 02:02 PM ----------
With the money you guys spend on payments for your 5.0 I'm putting that to trick flow heads forged bottom and blower.
So 4.6>5.0
Old 11-18-2013, 03:10 PM   #11
So 4.6>5.0
Well my car was 27k and it makes 432rwhp after only $1200 in mods. How much money does it cost to get a 4.6 to 430rwhp? Easy 5k blower and another 5-7k on a built motor? Then you have to build everything else around the motor because the Trans is soon to go after. So by the time you are on a solid competing level with a full bolt on coyote how much did you spend
My payment is 423 a month BTW
Old 11-18-2013, 03:13 PM   #12
My payment is 0 bucks a month with 2gs towards a vortech DIY plus what it costs to build the motor
Old 11-18-2013, 03:13 PM   #13
Originally Posted by ZLwhat View Post
Well my car was 27k and it makes 432rwhp after only $1200 in mods. How much money does it cost to get a 4.6 to 430rwhp? Easy 5k blower and another 5-7k on a built motor? Then you have to build everything else around the motor because the Trans is soon to go after. So by the time you are on a solid competing level with a full bolt on coyote how much did you spend My payment is 423 a month BTW
truth, a 5.0 will always be faster for LESS than how much the 4.6 owners spend, sorry, that's the cold hard truth.
Old 11-18-2013, 03:18 PM   #14
Well I have a procharged 4.6 in my truck and I had to put a built motor in it. I don't know how to build them and I ended up going to promar for a motor. By the time I had it in the truck I spent nearly 6k on the motor and who knows how much on odds and ends. I think they cost more than the engine itself lol. Either way I was able to crank up the boost and my truck made 358rwhp on 37s before I blew up the input shaft on the Trans. There went another 4k for a built Trans and now I have a truck worth 4k with 15k worth of engine and Trans and a 5k supercharger on top of it . Should have bought a diesel.
ID:	136980   Click image for larger version
Old 11-18-2013, 03:53 PM   #15
Again like I said how does it cost less to fix a coyote when you have to buy the 30 thousand something dollar car first??
Buying a used car and fixing it up is cheaper than buying a new car and still having to fix it up
---------- Post added at 02:53 PM ---------- Previous post was at 02:51 PM ----------
Also I'm gonna laugh when that one guy finishes his Mach 1 LS swap and smokes the coyote and 4.6 owners on here lol
Old 11-18-2013, 04:12 PM   #16
That LS motor will still need heads, cams, and an intake before he is "smoking" any body. The 4.6 crowd will be SOL from the start. Just look at the 01 SS camaro. Running 12.8-13 flat stock with the LS1. His new edge will be at 3400# give or take with a 325HP engine. That's more HP than a 05-10 GT and less weight. Add H/C/I and he could easily make 400+rwhp with no real power adders. Easy 11 second ride all day.
Don't get me wrong, I can't stand the way modern Chevys look and the only cars I find attractive are the new vettes. BUT I've been around racing long enough to know that a LS motor is easy reliable power, and their bottom ends are stout.
Old 11-18-2013, 04:18 PM   #17
That LS motor will still need heads, cams, and an intake before he is "smoking" any body. The 4.6 crowd will be SOL from the start. Just look at the 01 SS camaro. Running 12.8-13 flat stock with the LS1. His new edge will be at 3400# give or take with a 325HP engine. That's more HP than a 05-10 GT and less weight. Add H/C/I and he could easily make 400+rwhp with no real power adders. Easy 11 second ride all day. Don't get me wrong, I can't stand the way modern Chevys look and the only cars I find attractive are the new vettes. BUT I've been around racing long enough to know that a LS motor is easy reliable power, and their bottom ends are stout.
too bad their rear ends aren't!! Lol
Old 11-18-2013, 04:18 PM   #18
gladiatoro's Avatar
Where do you get your information ? I spent 4 k on a e-force blower like new with 1000 miles on it , 12k I paid for my car I got a good deal second owner it's mint , 5 k on cosmetic mods , low pro Toyo tires /20" rims , lowered etc for a total of 21 k and I have a custom ride with 450 RWHP running a 3.5 pulley , kenne bell boost a pump etc..
The 2005 to 2010 3v 4.6 L can handle 450 to 500 RWHP no problem all day any day , no forging necessary , It's all in having a GREAT TUNE , just like the coyote if you go above 600 at the Crank Hp things will EVENTUALLY break just a matter of time so no benefit there.
You spent 28 k for 430 rwhp without custom rims/tires or lowered .
So for 21 k I have a custom ride with 450 rwhp or around 550hp at the crank
I think a GREAT deal. And I have NO PAYMENT.
Winner 4.6
Old 11-18-2013, 04:19 PM   #19
Where do you get your information ? I spent 4 k on a e-force blower like new with 1000 miles on it , 12k I paid for my car I got a good deal second owner it's mint , 5 k on cosmetic mods , tires rims , lowered etc for a total of 21 k and I have a custom ride with 450 RWHP running a 3.5 pulley , kenne bell boost a pump etc.. The 2005 to 2010 3v 4.6 L can handle 450 to 500 RWHP no problem all day any day , no forging necessary , It's all in having a GREAT TUNE , just like the coyote if you go above 600 at the Crank Hp things will EVENTUALLY break just a matter of time so no benefit there. You spent 28 k for 430 rwhp without custom rims/tires or lowered . So for 21 k I have a custom ride with 450 rwhp or around 550hp at the crank I think a GREAT deal. And I have NO PAYMENT. Winner 4.6
:twerk:
Old 11-18-2013, 04:23 PM   #20
gladiatoro's Avatar
or transmissions.
Old 11-18-2013, 04:25 PM   #21
Originally Posted by clflorida View Post
Here we go...
This thread was created specifically for the bickering, look at the original post.
Old 11-18-2013, 04:49 PM   #22
Eturner's Avatar
Depends on which 5.0 your talking about!.. The old school, or the new Coyote?..
Old 11-18-2013, 04:51 PM   #23
it can be both. All ideas are welcome in this thread
Old 11-18-2013, 04:56 PM   #24
Winner 4.6
If you want to get down to nitty gritty I traded my stock wheels +$300 to get nice wheels. Then I sold nicer wheels for more than they were worth and bought what I have now. Also, I sold stock suspension parts for $250 all together and spent $180 on my LCA'S and got the UCA for free through a promotion. So I made $70 there. So that puts me at $28k for a car with suspension work and wheels/tires for 28k and it will run with your "500hp" 4.6 all day. Let me know when your 4.6 runs less than a 13 second time slip and post it. Then I'll post my NA 5.0 time slip and well see who is faster. Sounds fair to me. You've spent 21k but just wait till you're putting another engine in it. It will be soon, and you'll be right there with me and how much I have spent.
Oh and just being honest, you got that e-force blower with 1k on it because the previous owner realized they are garbage and got rid of it. I don't think edelbrock even uses their blowers on their race cars LOL!
Old 11-18-2013, 05:04 PM   #25
Idk how this slipped my mind but termi>5.0
2000 cobra r >5.0
5.0>my 2v though lol
Old 11-18-2013, 05:10 PM   #26
the new coyote, well, that's the one I will refer to.
Old 11-18-2013, 05:26 PM   #27
gladiatoro's Avatar
WRONG the owner sold it because he bought a vette and wants to put money in that for drag racing , he kept his GT for a daily driver same car as mine .
AND sorry Edelbrock doesn't make Junk the e-force is a great BLOWER very efficient and same internals as the ZR1 , a twin roots set up , it produces more HP and tq than the competition at a lower boost level , do some research for God sakes......
Old 11-18-2013, 05:35 PM   #28
For the money i'll take a 4.6 any day. Not a fan of the land yacht S197 chassis. If I wanted to feel like I was driving a truck I would buy a truck.
Old 11-18-2013, 05:36 PM   #29
gladiatoro's Avatar
Also I told you it's all in the TUNE to have a happy engine and keep the psi under 10. You should learn more about SUPERCHARGERS there is a reason the ZR1 has one the fastest vette ever , the Camaro Zl1 has one etc... blowers are used because they make BIG POWER simple as that.
And you still spend 28 K and I spent 21 and I have 450 RWHP and you don't .
Winner again 4.6 L
Old 11-18-2013, 05:45 PM   #30
http://youtu.be/vdNaN-Dqy9o
http://youtu.be/VFHrXlpRUjY
Old 11-18-2013, 05:51 PM   #31
Screaming Mach's Avatar
4.6 4v ftw
Screaming Mach is offline   Reply With Quote
Old 11-18-2013, 06:01 PM   #32
Drive something slower than a truck so you don't feel like you are driving one? Makes sense
Don't have any problems with 5.0 cars in my 4.6 vert. I have respect for the capabilities of the platform but will still take my 4.6 anyday.
Old 11-18-2013, 06:04 PM   #33
I can build a ratty *** pushrod 5.0 for 1/3 the price of a new 5.0 that will rape it in the 1/4. Is it a nicer car? No.
Another example, if you get into a 2V for $4-$6k and then spend another $15k in mods to make it a mint 500-600whp car is it better than a new 5.0 that cost the same or a little more? You be the judge. IMO the S197 is more of an everyday driver comfortable car to drive around in that is fast as ufck with the Coyote in it.
Then there is the Terminator which is the exception to all the rules. Faster than a raped ape, lighter than the Coyote, seats that do not suck, IRS, 6 spd, fully forged and supercharged from the factory, true collector car that is going UP in value if you keep the miles off.
And as always, he who has the deepest pockets wins. All the platforms can be built to be 4 digit power no problem.
Old 11-18-2013, 06:06 PM   #34
I can build a ratty *** pushrod 5.0 for 1/3 the price of a new 5.0 that will rape it in the 1/4. Is it a nicer car? No. Another example, if you get into a 2V for $4-$6k and then spend another $15k in mods to make it a mint 500-600whp car is it better than a new 5.0 that cost the same or a little more? You be the judge. IMO the S197 is more of an everyday driver comfortable car to drive around in that is fast as ufck with the Coyote in it. Then there is the Terminator which is the exception to all the rules. Faster than a raped ape, lighter than the Coyote, seats that do not suck, IRS, 6 spd, fully forged and supercharged from the factory, true collector car that is going UP in value if you keep the miles off. And as always, he who has the deepest pockets wins. All the platforms can be built to be 4 digit power no problem.
thank you
Old 11-18-2013, 06:07 PM   #35
You are talking about a 4v cobra? That's an exception to the rule. Cobras can cost almost as much as a coyote in some cases also
02:46 AM
