Leaking brakes - Mustang Evolution
Old 11-30-2013, 10:14 PM   #1
Tyoung68's Avatar
Leaking brakes
Sooo i have problem with my master cylinder when i step on my pedal and release brake fluid shoots out of my master cylinder so do i need a brake residual valve? I also cannot lock up my brakes the fluid has already pealed my paint off so i would like to get this settled pretty soon! Any help is appreciated !
Old 12-01-2013, 11:50 AM   #2
Bgrizzzle's Avatar
Region: New Mexico
check the linings around the master cylinder, Check the top to make sure it is on tight and is not filled up to much. While your doing that it would probably be a good idea to double check your lines so every thing else is working properly.
Bgrizzzle is offline   Reply With Quote
Old 12-01-2013, 02:22 PM   #3
Tyoung68's Avatar
I have i even bent my clip more so it would be tighter but no luck i know its coming from the master cylinder because it sprays up out of it when you release the brake pedal
Old 12-02-2013, 12:48 AM   #4
Bgrizzzle's Avatar
Region: New Mexico
Dang that's really weird. Video? Has to be a hole in the top
Old 12-02-2013, 01:02 AM   #5
Tyoung68's Avatar
Ill try to take a video i think what is happening is that the brake fluid is being sprayed agains the cap and the its leaking around the edges
Old 12-02-2013, 01:12 AM   #6
87LX306's Avatar
For sure air in the system. Grab a few tube nuts and a few small sections on brake line to flare the nuts on and bench bleed the master cylinder. Afterwards bleed about another quart or so of brake fluid around all 4 corners of the car.
87LX306 is offline   Reply With Quote
01:59 PM
