Pypes axle back too loud - Mustang Evolution
Old 12-12-2013, 02:46 PM   #1
Cise's Avatar
So I just put a set of Pypes-Pype Bombs on my 2014 and I find they're actually a little too loud, and the fit sucks. does anyone have any recommendations for a better alternative?
Cise is offline   Reply With Quote
Old 12-12-2013, 07:29 PM   #2
FastFord13's Avatar
There are many different aftermarket axelbacks for our cars. YouTube is your friend here.
Old 12-12-2013, 07:33 PM   #3
Pony123's Avatar
Wanna sell em?
Pony123 is offline   Reply With Quote
Old 12-12-2013, 07:42 PM   #4
Ucfknight's Avatar
If you can, give them a week or 2. All my exhaust set ups sounded too loud at first too but the sound calm down after a while.
Ucfknight is offline   Reply With Quote
Old 12-12-2013, 07:46 PM   #5
Cise's Avatar
I'll give it some time then, thank you
Old 12-13-2013, 04:10 AM   #6
bucko's Avatar
But that won't fix the fit issue the OP also mentions.
Old 12-13-2013, 05:59 AM   #7
FastFord13's Avatar
Pypes are notorious for having fitment issues.
Old 12-13-2013, 07:05 AM   #8
Take them to an exhaust shop and have them welded in place to fix the fitment issues.. mine aren't centered in the cutouts either and it bothers me but i can deal with it. As for the noise, put at least 100 miles on them if you havent already and they will quiet down. I also put shorty headers on mine and it made it a tad bit less loud but made it deeper at the same time.
Deep_Impact is offline   Reply With Quote
Old 12-13-2013, 01:49 PM   #9
Cise's Avatar
The figment bugs me because they are pushing up against the bumper, how much do you think it would to get it aligned?
Old 12-13-2013, 04:45 PM   #10
pony17's Avatar
I just put the pypes bomb in my 2013 v6 and i love the sound, and i dont have fit issue i just remove the screw of the cats and put the pypes bomb
pony17 is offline   Reply With Quote
Old 12-13-2013, 04:47 PM   #11
Fenderfreak145's Avatar
You need to loosen up the mid pipe (If you haven't done that already) so it won't rub.
If you've done that and the left side is still rubbing you'll need to tweak it a bit. It rubbed on mine for a while (ANNOYING) until I took it all apart then put it back together knowing it would slide to the left.
The right side had a problem with vibration since the hanger is so much closer to the little L bend in the rod that it vibrates and makes a metal-on-metal sound...basically terrible...but some rubber tube fixed that up.
These are definitely a project but you can make them sound pretty damn good.
2016 Black GT PP
Fenderfreak145 is offline   Reply With Quote
Old 12-14-2013, 01:04 AM   #12
powerwhee's Avatar
Sounds likes it not worth the cheap price. Why wouldn't you just get muffler deletes at an exhaust shop done, essentially what the Pypes is.
powerwhee is offline   Reply With Quote
Old 12-14-2013, 02:54 AM   #13
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I fixed the fitment issue pretty easily. Just loosened the Pype bombs enough to adjust them, folded a towel two or three times and tucked it between the Pypes and the bumper, this held it center, then retightened the Pype bombs. Still center to this day.
2012 Kona Blue 3.7L V6:
Old 12-14-2013, 09:55 AM   #14
+1, this works very well. i did this on the install but its been about a year now and they have shifted and no longer center. i just havent had the time to fix them
Old 12-15-2013, 06:39 PM   #15
Just installed the Borla Touring... I love it
azhuskcarr is offline   Reply With Quote
Old 12-15-2013, 06:48 PM   #16
I had them in all summer I love the sound and the drone and loudness reduces a tiny bit but still too much drone at times. Ill probly go borla when I unstore my car in spring.
the_stig is offline   Reply With Quote
Old 12-17-2013, 05:57 AM   #17
bucko's Avatar
This is where I have a problem. I may bite the bullet and pay more to have a muffler shop correct a fitment issue, but if they still don't look right, especially in the area of where the tips exit the back, then I would go no further. There are so many other manufacturers of axle back exhaust systems out there. Why should any of us have to settle for poor fitment? Why hasn't this manufacturer stepped up and corrected the problem?
Old 12-17-2013, 10:51 AM   #18
FastFord13's Avatar
Well said, as they (pypes) must be aware of the poor fitment issues but still do nothing to correct it. It has been well documented on this forum alone that they are probably the worse axelback for fitment problems. Customers sholdnt have to just except it and have to have them fixed.
Old 12-17-2013, 11:15 AM   #19
Pony123's Avatar
Other companies are double the price. That could be the reason.
Old 12-17-2013, 01:44 PM   #20
FastFord13's Avatar
I guess you get what you pay for.
Old 12-17-2013, 01:49 PM   #21
bucko's Avatar
the reason why I would not be buying them....
Old 12-19-2013, 07:24 AM   #22
SixBanger's Avatar
I suggest waiting a while. When I put my Bassani's on, around 2500-3000RPM the interior resonance reached a pitch that felt like it was going to make my head explode. I remember driving the girlfriend around that day on a 30 minute trip and it gave her a head ache. BUT, I gave it 1000 miles and it doesn't make that sound at all anymore. Much better.
And if at the end of your two weeks you decide that they Pypes are still too obnoxious, the Bassani's are a very good $560 option on AmericanMuscle. A couple hundred more expensive than the Pypes, but hundreds of dollars less than the Borla ATAK (which would have been my first choice if it weren't pushing $800). Quality is great. The welds are solid and the steel is nice and polished out of the box. Fitment has no issues. The Bassani's (as well as almost all axle-backs) are much smaller and substantially lighter than the gargantuan mufflers that come from the factory. Plus the 4" tips are bad ***.
SixBanger is offline   Reply With Quote
05:20 PM
