clutch pedal - Mustang Evolution
Old 12-12-2013, 05:16 PM   #1
TXstang125's Avatar
clutch pedal
Hey guys I got my clutch put in and and just got it back and now there is a tone of slack in the pedal , as soon as I start to let the clutch out like less than an inch it engages how can I adjust it ?
-I have a aftermarket cable with a new quadrant and fire wall adjuster
TXstang125 is offline   Reply With Quote
Old 12-12-2013, 06:51 PM   #2
Take the adjuster and turn it towards the firewall more. Do it in small increments and test as you go.
Old 12-12-2013, 07:31 PM   #3
Adjust it at the firewall. Put it on ramps, have 2 helpers. 1 helper in the car for safety, 1 helper at the firewall, you under the car with it running. With the dust shield off, hace helper at the firewall adjust it until the TOB starts to spin. Then 1 click tighter and button it up. Your clutch is now adjusted properly.
Old 01-27-2014, 03:05 PM   #4
TXstang125's Avatar
Is the TOB supposed to spin when the pedal is out ?
Old 01-27-2014, 04:41 PM   #5
Yes there should be a slight preload on the TOB, it is designed to work this way. If there wasn't it would be going 0-6000 rpm in a matter of a second. Not good and smells like burnt clutch.
12:01 PM
