Automatic vs. manual - Mustang Evolution
Old 12-16-2013, 07:02 AM   #1
PISTONS8904's Avatar
With the select shift is there really a big difference?
PISTONS8904 is offline   Reply With Quote
Old 12-16-2013, 07:19 AM   #2
badblue11's Avatar
Absolutely. If you've ever driven a manual u would know the difference. The automatic can be shifted but only one gear up or down at a time. I can choose whatever gear I want It to go into right then and there. Not to mention the automatics rear end ratio is 3.31 while the manual is 3.55 without track pack and 3.73 with the track pack. The manual transmission is the only way to go of your driving a GT
badblue11 is offline   Reply With Quote
Old 12-16-2013, 07:27 AM   #3
KARgt13's Avatar
The auto is 3:15 I believe. The manual is 3:31 or 3:73 with track pack. Optional 3:55.
As for the question, yes, there is a huge difference, they aren't really comparable at all.
KARgt13 is offline   Reply With Quote
Old 12-16-2013, 07:42 AM   #4
So what about better shifts at the drag?
Old 12-16-2013, 07:47 AM   #5
badblue11's Avatar
The manual
---------- Post added at 02:47 PM ---------- Previous post was at 02:46 PM ----------
Just because of the rear end difference there's like 3 tenths of a second difference 0-60 time between the two
Old 12-16-2013, 08:13 AM   #6
TorchRed6's Avatar
auto will be much more consistent. get a good tune and youll blast throught the gears just like you would if you had a manual.except theres no room for driver error. just stomp the gas and hold on. autos better for the strip. not as fun though. factory gearing isnt important. you can change those out easy.
TorchRed6 is offline   Reply With Quote
Old 12-16-2013, 01:21 PM   #7
Region: West Virgina
Must have an auto huh?lol I have never had an auto in a muscle car. Its just not the same. That's me though. My dad has always had vettes and likes the auto.
Green5.0 is offline   Reply With Quote
Old 12-16-2013, 01:58 PM   #8
badblue11's Avatar
For me, unless you have a double clutch transmission like a gtr or lambo, always drive a manual
Old 12-16-2013, 02:00 PM   #9
bucko's Avatar
How is this an explaination for the manual transmission use?
Old 12-16-2013, 02:10 PM   #10
KARgt13's Avatar
Unless your car has a potato, drive manual.
Old 12-16-2013, 02:13 PM   #11
badblue11's Avatar
Just a personal preference. Manuals the only way to go
Old 12-16-2013, 02:21 PM   #12
TorchRed6's Avatar
i do yes, but not by choice. i wanted a 5 speed but i couldnt find any within a comfortable price range at the time.
Old 12-16-2013, 02:52 PM   #13
Grabber Blue5.0's Avatar
Autos come with 3.15's there chief.
The manual
That's a bull crap statement and you know it. Don't make up stuff that's just not true.
Old 12-16-2013, 11:25 PM   #14
Autos nowadays will always win in a straight line because they are easier to launch and they shift perfect every time. But I autocross so I need to make sure my car stays in the gear I need it, and I'll be spinning around 4-5k+ rpm most of the time so I need to be the one to pick the gear. So manual for me in that case.
They each have purposes, neither is "better"
Old 12-17-2013, 12:54 PM   #15
Since I was on drag slicks last week in the snow, I never would have pulled it off in an auto car. Being able to slip the clutch, not have a torque converter decide what power I need, plus being able to start in any gear I like, helped a lot in that circumstance.
However, if, in 2012, the auto was worth a damn in stock form, (i.e. firm shifts, select shift with quick response, available BBP), I would have considered it.
Old 12-17-2013, 01:02 PM   #16
KARgt13's Avatar
The '15 auto will have paddle shifters apparently.
Old 12-17-2013, 01:05 PM   #17
Personal preference for your street car. If you do a lot of circle track/cone/road racing get a stick. The auto will skull **** you at the 1/4 track though.
edit: No I am not talking about a stock AOD or some crap I'm talking a about a fresh up to date automatic with a jmod/shift kit and a nice aftermarket stall converter. Will drop your balls into your feet at the tree and power does not let up till you let off the gas.
Old 12-17-2013, 01:47 PM   #18
Huh?
You seemed to be confused what we're talking about here. There's no jmod or shift kit for the 6R80 in the 2011+ cars and no need for that crap.
Old 12-17-2013, 05:59 PM   #19
2011's Avatar
Manuals are faster in the 1/4 stock for stock. I have a manual with stock 3:31 gear and beat a stock auto at the drag strip this year.
2011 is offline   Reply With Quote
Old 12-17-2013, 06:00 PM   #20
Stock if it's left in drive but use the select shift and it will be neck and neck.
Old 12-18-2013, 03:56 AM   #21
And yet another one with a B.S statement. What is your best time stock?
Old 12-18-2013, 04:25 AM   #22
Screaming Mach's Avatar
Looks like the auto is a little slower hmmm
Screaming Mach is offline   Reply With Quote
Old 12-18-2013, 04:42 AM   #23
Tpost08's Avatar
They've had cars with less than 20 miles on them straight off the lot not mods run 12.5. Manual MIGHT be quicker from the factory.... Might. But put the same tune on both auto and manual and the auto takes over easily. Auto off the lot has bad shift points and delayed throttle response.
---------- Post added at 05:42 AM ---------- Previous post was at 05:40 AM ----------
Easily seen that the fastest 2011+ 1/4mile is an auto. Along with the second and third fast times in the 1/4. Autos have been greatly improved since back in the day.
Tpost08 is offline   Reply With Quote
Old 12-18-2013, 04:59 AM   #24
Hey don't get me wrong the auto has come a long way and like what was stated a few mods the auto is quicker and is always consistent but they were talking stock for stock
Old 12-18-2013, 06:09 AM   #25
Huh?
I probably should have clarified.
I'm talking about the 4R trannies/AODs for the jmod/shift kit. I know the 6R just needs a tune and runs a mid 12 all day. Some old guy up at Englishtown had a bone *** stock Coyote automatic except for a handheld tuner running consistent 12.4-12.6s. Not going to do that in a stick, at least not all day like this guy was with little/no track experience.
Throw a good aftermarekt triple disc stall converter in a Coyote and its a joke lining up against the same car with a stick shift.
Old 12-18-2013, 06:30 AM   #26
Tpost08's Avatar
Stock for stock. Auto wins 3 out of 5 times with a good manual driver. Put somebody that doesn't have track time. Then auto wins ever run unless it's in reverse.
Old 12-18-2013, 06:35 AM   #27
This is truth. Dude that has never been to the track is going to run much slower in the stick then a guy who can just floor it and hang on with the auto. Call that lazy or cheap or whatever derogatory thing you want lol. The auto still crosses the line first. FACT=the manual is a liability/handicap at the 1/4 mile.
Old 12-18-2013, 06:41 AM   #28
Kylemittelman's Avatar
Stock manual is gonna beat stock automatic every time. There's a reason all the best track and strip cars are manual. You can control your rpms making for faster acceleration. If it's a good driver
---------- Post added at 08:41 AM ---------- Previous post was at 08:40 AM ----------
Only if it's an inexperienced driver. At which point they shouldn't be racing anyway.
Kylemittelman is offline   Reply With Quote
Old 12-18-2013, 06:57 AM   #29
Ok you've obviously never been to a track if you think all the fastest cars are sticks.
Old 12-18-2013, 09:45 AM   #30
2011's Avatar
12.8 112 mph stock
---------- Post added at 11:45 AM ---------- Previous post was at 11:43 AM ----------
I ran this year. I ran a 12.8 at 112mph. More then bs
Old 12-18-2013, 09:45 AM   #31
How do you view someone's pictures on this app? It has changed or been updated.
Old 12-18-2013, 10:01 AM   #32
12.8 112 mph stock
No, that's about what they run on average. High 12s, low 13s with an average driver. With an average driver the autos do high-mid 12s and I have seen this with my own eyes.
Like I said earlier I am not here to tell a person which transmission is better for their cars, its just lol worthy when you get people who have obviously never been in a fast auto or even been to the track saying how much faster a stick is in a drag race. Maybe between a stock 1994GT auto/stick but not anymore, not for awhile really.
Old 12-18-2013, 10:03 AM   #33
What's better in auto mode running it in straight drive or sport mode using the select shift?
Old 12-18-2013, 10:22 AM   #34
Get yourself a good 93 octane tune with the shift points firmed up, leave it in drive and call it good.
Old 12-18-2013, 10:23 AM   #35
Bear376's Avatar
A driver can have a lot of fun with a stick. However, in almost every category, the automatic is the better choice. I love manuals, and my learning how to shift was in a 289 HiPo 65' Mustang. My wife's car has a manual, with 210,000 miles on the original clutch. The only place where a manual has an advantage is on road courses, and an automatic can be setup to be competitive even then.
It is only going to be even more slanted to the automatics in a few years when all manufacturers go to 9-10 gears and more options appear for driver controlled shifting. In any case, the better the driver, the better the results. Anyone who likes shifting, should buy a manual and not worry about how it compares with an automatic. If a car is a going to spend a lot of time doing routine town driving, a manual is going to get old fast.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
« more torque. | Cams »
04:21 PM
