NITROUS 3V - Mustang Evolution
Old 12-20-2013, 05:47 PM   #1
s197v8's Avatar
NITROUS 3V
I just got a zex wet nitrous system for my 07 gt, how high of a shot should I run if im only using it once a month? And also what else do I need to run safely?
s197v8 is offline   Reply With Quote
Old 12-20-2013, 05:52 PM   #2
BaSohol's Avatar
You need new spark plugs, 2 step colder if it's a 100 shot or more and a tune would help to
2007 Ford Mustang GT 5spd
Old 12-20-2013, 06:02 PM   #3
Torchredfrankie's Avatar
Do a 75 shot only use 100 if you really wanna beat the guy next too you.
Torchredfrankie is offline   Reply With Quote
Old 12-20-2013, 06:09 PM   #4
s197v8's Avatar
What about a 175shot? What would I need to run that, if im only using it rarely?
Old 12-20-2013, 07:59 PM   #5
08mustanggt's Avatar
A forged bottom end probably lol
08mustanggt is offline   Reply With Quote
Old 12-20-2013, 08:03 PM   #6
s197v8's Avatar
What would that cost?
Old 12-20-2013, 08:15 PM   #7
A good rotating assembly is about $2, 000 and then install is about $2, 000
---------- Post added at 08:15 PM ---------- Previous post was at 08:14 PM ----------
But the car should be safe to a very high hp level. Nitrous is nothing at that point, you can throw a blower or turbo in and make stupid horsepower
Old 12-20-2013, 08:23 PM   #8
Kaboom
Old 12-21-2013, 11:05 PM   #9
Franco09GT's Avatar
On stock bottom end you'll probably blow the engine & you'll need to upgrade your fuel system to run a 175. You can run a 100 or 125. Go with ford racing 0 degree plugs (NGK 7554, part#) they are made for nitrous & boost. & definitely get a tune for nitrous. I was running a 100 for a couple months & recently bumped up to 125. Feels GOOD! 55k miles, full bolt ons & cam.
Franco09GT is offline   Reply With Quote
Old 12-22-2013, 08:13 PM   #10
White03GT's Avatar
There goes the rings. Forge it for that big of a shot
White03GT is offline   Reply With Quote
Old 12-23-2013, 07:59 AM   #11
Fuel system, GOOD dyno tune, window switch setup, colder plugs and a 125 shot. PROPERLY running nitrous is not as big a deal as ppl think. You will not hurt your motor if you have a good tune and a proper setup. You can run a good setup every weekend and have 0 issues or a crap setup once and blow the whole thing up.
2000 Mustang GT Steeda #0048
01:21 AM
