Whiteline Watts Link Rear Suspension - Mustang Evolution
Old 12-20-2013, 11:20 PM   #1
NewMtang's Avatar
V6s or V8s
Any of you guys/girls out there using the Whiteline Watts Link Rear Suspension (American Muscle, part# 54111)?
Old 12-21-2013, 11:41 AM   #2
Siber Express's Avatar
Back of the car is basically the same so same thing.
Old 12-21-2013, 04:01 PM   #3
You will corner like a boss with a WL
Old 12-21-2013, 05:11 PM   #4
fastmustangs1's Avatar
Get rid of the UCA altogether to free up the rear. Add on a torque arm as well.
fastmustangs1 is offline   Reply With Quote
Old 12-21-2013, 06:31 PM   #5
alrefire's Avatar
I haven't seen you post here before...
This man is a genius when it comes to suspension.
He's my mentor.
Old 12-21-2013, 11:32 PM   #6
Watts link, Torque arm, and coilovers. You will see some Subie headlights in the corners.
Old 12-22-2013, 12:46 AM   #7
NewMtang's Avatar
I have two different ways to go. UCA, with Whiteline Adjustable Rear Upper Control arms...$1,142 with 6% discount or....
Rear UCA, Lower Adjustable Control Arms, Brackets for Lower Arms, Whiteling Adjustable Pan Hard Bar and Pan Hard Support Brace....around $900 with 6& discount.
Why coil overs? I already have the Ford Racing Handling Package installed. New Springs with it.
Old 12-22-2013, 04:27 PM   #8
Don't bother with upper control arms, just go straight to a Torque arm, and as for the coilovers they are fully adjustable for stiffness and ride height.
Old 12-22-2013, 05:21 PM   #9
It's not me, it's you.
primer2tone's Avatar
Even with the coilovers the spring is just sandwiched between the axel and body. I wish they had a coil spring setup similar to the front suspension.
Old 12-22-2013, 05:27 PM   #10
alrefire's Avatar
Last time I checked, they are available
Name:	ImageUploadedByMustang Evolution1387758420.359993.jpg
Old 12-22-2013, 05:29 PM   #11
Yup, I actually just decided to check and sure as ****, they do have them. Looks like I'll be swapping out my coil overs.
Your pic shows coil spring in strut and a watts link. Do you have a link so I can research?
Old 12-22-2013, 05:43 PM   #12
alrefire's Avatar
Griggsracing.com
There rear suspension kit is my next step
Then there SLA
Old 12-23-2013, 09:44 AM   #13
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Originally Posted by NewMtang View Post
V6s or V8s
Whiteline makes a great product! I run their Lower Control arms on my 2011 GT and have full intentions of getting the Watts Link set up. The Whiteline Watts Link Rear Suspension allows the axle to move up and down in a true vertical plane keeping it centered under the car, so that your roll center behaves exactly the same in a left hand turn as it does in a right hand turn. This allows for predictable and tune-able handling, perfect for street and track cars.
These are also ride height adjustable. So it doesn't matter if you're Stock, Lowered on Springs, Coil overs etc.. you can still use the Watt links set up!
I hope this helps. It sounds like you have some really big plans for your Suspension. That's really cool to see! Keep up the great work with your build and let me know if you ever have any questions.
-Dan
Old 12-23-2013, 07:11 PM   #14
NewMtang's Avatar
Ok, why should I get rid of the UCA altogether? Adding a torque arm for track use?
Beginner here.
THANKS,
Old 12-23-2013, 07:21 PM   #15
NewMtang's Avatar
-Dan
Someone mentioned that I should put on some Coilovers. I already have the FRHP system. I thought I took care of most of the suspension with this package. Or could it be they didn't notice the ad-ons?
Old 12-24-2013, 09:00 AM   #16
AmericanMuscle.com
Sponsor
Coileovers are a great option over the stock suspension. However, so is the FRPP System that you're running. You won't notice all that much of a difference in handling and ride quality from your current suspension set up, to coilovers. The only thing you'd really gain is the ability to adjust the ride height!
I don't think it's necessary to run Coilovers, if you're already running a great Suspension set up.
Hope this helps!
-Dan
Old 12-24-2013, 09:40 AM   #17
Griggsracing.com
Then there SLA
Prepare thy wallet/anus...
Beginner here.
THANKS,
The stock 4 link suspension is marginal at best for keeping the rear end of the car properly situated. Going to a torque arm/panhard setup/3 link eliminates side to side play and drastically improves the entire way the rearend operates. A Watts link is even better because a panhard bar does not quite allow the rear to articulate up and down in a true vertical fashion as was already mentioned, the Watts link does.
There is also the much maligned IRS which, IMO, is the better option for a street car. If you are on a prepped track the built SRA/watts/etc... is going to shine but for an unprepped daily driven road with bumps, potholes and whatever else I'll take a properly setup IRS any day. That's just me though, YMMV.
Then for up front there is the SLA setup which is a bit overkill for a non-competition road racer but it all depends what ppl want to do. For the majority of ppl a good front coilover setup/k member like the $1700 Max Motorsports front kit with forward offset A arms will be MORE than fine.
Old 12-24-2013, 07:03 PM   #18
NewMtang's Avatar
I choose the FRHP because I wanted a one time drop on the car. No track or road course use. Just a little V6 that has a little bit bigger balls than stock cars. Your right about back roads. Beats the H*ll out of you but I knew that was going to happen. Rather cruise on the interstate.
Thanks for your response.
Merry Christmas....
10:20 PM
