2001 gt looking for around 450 or 500 - Mustang Evolution
Old 12-23-2013, 05:06 AM   #1
Dustin541's Avatar
Region: Oregon
I was thinking about trick flow heads later on it is gonna get some boost most likely a centri or turbo should i skip the heads and go straight to boost
As of now the car has an eddy intake believe it has 50lb injectors neither are installed yet just sitting
270ah comp cams
Cobra crank probe pistons and rods
Accel super coils 3.73 gears t45 with spec 3+ and steeds tri-ax and of coats full exhaust and CAI and bbk 78mm T/B
Dustin541 is offline   Reply With Quote
Old 12-23-2013, 10:00 AM   #2
Slow4V's Avatar
My friends GT made 460-480rwhp
- Built shortblock ( Forged )
- Stock heads and cams
- Tork Tech kit on 15psi
- Liberty / TKO transmission ( Spec Clutch and flywheel )
- built rear end
But blew a Piston Ring , he thinks they didnt do a good job on the work.
Old 12-23-2013, 12:27 PM   #3
Slow4V's Avatar
Stage 2 cams too
Old 12-23-2013, 12:30 PM   #4
Dustin541's Avatar
Region: Oregon
If I am gonna boost it's gonna be centrifugal probably fairly low for awhile
Old 12-23-2013, 12:32 PM   #5
Slow4V's Avatar
Just save like 10-15,000
Because that's min your going to spend.
Old 12-23-2013, 12:34 PM   #6
Dustin541's Avatar
Region: Oregon
My limit for parts is "8000" according to my wife lol but with my saleen and my jeep taking some of the funds it's not as good as it sounds
Old 12-23-2013, 12:35 PM   #7
Slow4V's Avatar
I'd save up for a 03-04 cobra if I were you
Old 12-23-2013, 01:39 PM   #8
Dustin541's Avatar
Region: Oregon
I thought about that but I don't think I can convince the wife to do that I just bought the 87 saleen and the 2013 gt
---------- Post added at 03:39 PM ---------- Previous post was at 03:38 PM ----------
Really I just like the 2001 and I want to build it up a bit then run big boost or nitrous down the line
Old 12-28-2013, 04:55 PM   #9
MMVEC's Avatar
A blower is going to run about $3500-$5500 for a decent setup. Then you have to install and tune it--not sure if you're doing this or a shop. But on a stock bottom end, you'll be limited to how much boost you can run. If you add heads, you're looking at another $3000 for the fully dressed trick flows plus installation. It's an ambitious plan to try and stay within the $8000 budget but you might need to bump it another few grand to get there.
Personally, I'm taking a different route. No power adder, just bolt ons; stock bottom end with baffled oil pan; high flow oil pump; electric water pump; fully dressed 38cc trick flow heads port matched to lower intake and upper intake as well to throttle body. 42lb injectors; calibrated air flow meter and all with a custom tune.
I figure this setup should net me about 350-365 reliable naturally aspirated horsepower. I want a balanced car that has good usable power from the mid-high range that has handling to match. I'll make up the lack of bottom end torque through a rear gear upgrade to either a 3:55 or 3:73. I figure my engine mods with a custom tune should easily cost less than $8k since I'm leaving the bottom end alone. My suspension setup is another story....
MMVEC is offline   Reply With Quote
Old 12-28-2013, 05:22 PM   #10
Black on Boss's Avatar
Does anyone ever bore/stroke the 4.6 2v? I'm not to familiar with it but I think it would be a beast NA
Old 12-28-2013, 05:27 PM   #11
Dustin541's Avatar
Region: Oregon
Got a screaming deal on a vortech V2 setup so I'm
Way under budget 450 should be easy
Old 12-28-2013, 05:28 PM   #12
Sounds good
Old 12-28-2013, 07:29 PM   #13
MMVEC's Avatar
You can get a stroker kit but they aren't cheap and it's a bit of work. You can bore a 2V but the most you can safely go is about 0.020" over--this due to the thin water jackets between cylinders.
If you must touch the bottom end and if you really want to up the displacement, don't bore anything. Just get a stroker kit, balance/blueprint the crank; pistons and align/hone the cylinder bores.
Again, not cheap to do if you want it done right. Plus you have to upgrade the top end; fuel delivery etc etc to get the most out of it. The benefits will net great gains but for the $$ outlay you'd be better off starting with a 4V....good luck either way.
12:05 PM
