Cobra IRS on a foxbody - Mustang Evolution
Old 01-02-2014, 08:49 AM   #1
mach5894's Avatar
Anyone know of anyone thats done this? If so can someone tell me the pros and cons of the conversion
mach5894 is offline   Reply With Quote
Old 01-02-2014, 10:12 AM   #2
It has been done. I do not believe it is a straight conversion onto the foxbody.
But pros is better ride and better handling
Con is that if you drag race it will be weaker than the SRA
Old 01-02-2014, 12:44 PM   #3
mach5894's Avatar
Ill be doing autocross and road racing, is the rear end of the irs same size or bigger than the fox? Ill be trying to put one on my 85 this winter
Old 01-02-2014, 12:46 PM   #4
It's a touch wider. I have a friend doing the same with an 86 at the moment. I know he has run into a few issues.
Old 01-02-2014, 12:49 PM   #5
Loc: Austin,TX
My buddy did this on his 91 fox and loved the ride afterwards.
Old 01-02-2014, 01:01 PM   #6
Mile high JDF's Avatar
The adjustability will be nice for road race and auto x. The ride is definitely smoother and the exhaust looks sexy. Down side is you're adding somewhere around 200 pounds to the car. Definitely do the FTBR bushing kit while it's out
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-02-2014, 03:20 PM   #7
mach5894's Avatar
What does the bushing kit do?
---------- Post added at 04:20 PM ---------- Previous post was at 04:19 PM ----------
Do you know what probs he ran into?
Old 01-02-2014, 03:58 PM   #8
Remember that foxbodies are also fairly light in the rear end. The extra weight in the rear will most likely help him out.
Old 01-02-2014, 05:46 PM   #9
What does the bushing kit do?[COLOR="Silver"]
It's a delrin bushing kit that helps reduce when hop as well as help tighten up thebrear end
That's true.
Old 01-02-2014, 08:35 PM   #10
mach5894's Avatar
That's true.
You know if I can still run 17x9?
Old 01-02-2014, 08:58 PM   #11
You should be just fine. I run a 17X10.5 on mine, but I know the New Edges have a wider wheel well to fit something like that
Old 01-02-2014, 09:09 PM   #12
mach5894's Avatar
Think I might have to roll mine out?
Old 01-02-2014, 09:14 PM   #13
Might be a good idea
Old 01-02-2014, 09:19 PM   #14
mach5894's Avatar
What if I got got custom backspaced rims
Old 01-02-2014, 09:41 PM   #15
I honestly don't know much about wheel spacing on a Fox. What's the biggest you can fit on a normal 8.8 fox?
Old 01-03-2014, 08:07 AM   #16
The IRS and any 99-up rear is something like 3.5" wider than the fox rear. You will be limited to an 8" wide rim and a 245 without a mini tub.
Old 01-03-2014, 08:22 AM   #17
mach5894's Avatar
What if I roll it out?
Old 01-03-2014, 08:29 AM   #18
Then you can go wider, maybe a 9" rim with a 255 or something on it. You're going to need to mini tub to run a fat tire like you want.
02:45 AM
