Upper and Lower Control Arms - Mustang Evolution
Old 01-02-2014, 02:25 PM   #1
Region: Nebraska
What lower and/or upper control arms do you prefer and why?
Found the 2013 Boss I just bought has terrible traction and wheel hop problems. So am gathering the parts I need to correct the problem.
nebob is offline   Reply With Quote
Old 01-02-2014, 02:46 PM   #2
tj@steeda's Avatar
You can check out the Steeda brand ... here is a video regarding our LCA's:
Steeda Billet Lower Control Arms - YouTube
And here is an article that you can check out showing our differences:
Not All Control Arms Are Created Equal Steeda Blog
Lastly, here is an article that was done regarding our Boss 302 LS with the Steeda upgraded UCA/LCA:
“Laguna Steeda” in the News Steeda Blog
2013 Steeda Boss 302 LS - Laguna Steeda - 5.0 Mustang & Super Fords Magazine
You can send me an email at tim@steeda.com if I can help with any other details?
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 01-02-2014, 06:18 PM   #3
Benzopyrene's Avatar
Man I am digin just looking at my BMR LCA's. Now I just got to put em on and try em out!
Benzopyrene is offline   Reply With Quote
Old 01-02-2014, 06:27 PM   #4
Black on Boss's Avatar
Exactly!
---------- Post added at 08:27 PM ---------- Previous post was at 08:26 PM ----------
I have heard great about BMR and that's who I went with. Still have to have them installed :/
Post some pics of that Boss!!
Old 01-02-2014, 07:04 PM   #5
Bodyman's Avatar
I had BMR on my 07 worked good no more wheel hop. With the brackets and LCA's.
Bodyman is offline   Reply With Quote
Old 01-03-2014, 09:34 AM   #6
Crewchief15's Avatar
Not All Control Arms Are Created Equal « Steeda Blog
“Laguna Steeda” in the News « Steeda Blog
Best Regards,
TJ
I have these lcas. Once you take your stock ones out, you'll quickly realize the problem. They are junk (the stock ones). These lcas didn't completely eliminate my wheel hop but it put a good dent in it. I still have the stock uca but the purchase was well worth it! Hope that helps.
Crewchief15 is offline   Reply With Quote
Old 01-03-2014, 09:50 AM   #7
tj@steeda's Avatar
Crewchief,
To your point ... these cars all re-act differently to the aftermarket suspension parts. There was a video on YouTube that showed the UCA in action ... and the issues it had.
Some people install the LCA's and the hop is gone ... some install the UCA and the hop is gone ... and sometimes consumers have to install both to completely eliminate the hop.
Thank you for the feedback and your insight.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 01-03-2014, 09:52 AM   #8
Crewchief,
Best Regards,
TJ
Yeah, I'm sure once I get the uca swapped, it'll be eliminated. Just dreading the install.
Old 01-03-2014, 10:46 AM   #9
Not such a big deal is you have a rattle gun, some ear defenders and the car is relatively new. It's the "big bolt" that is the hangup, otherwise, it's pretty standard socket wrench stuff.
No rattle gun? 2' of pipe on a 1/2 inch socket wrench and turn to TIGHTEN the bolt a touch first, then it'll likely wind right off. This technique works when I am rebuiding turbos, which have the most stuck bolts on planet earth so, it'll work here, too.
Old 01-03-2014, 10:48 AM   #10
Cheater bars for the win!
Old 01-03-2014, 07:12 PM   #11
Yeah I'm holding off on uppers. I'll have a bunch of other stuff though
Old 01-03-2014, 07:37 PM   #12
Crewchief,
Best Regards,
TJ
Watch the videos this guy posted and you will realize why you NEED an UCA and bracket. I have mine in the garage just dreading the install lol.
http://www.svtperformance.com/forums...-want-see.html
Old 01-03-2014, 10:51 PM   #13
ati347's Avatar
Region: Iowa
I put the upr pro kit on mine with relocation brackets and have no wheel hop. This set up is not for everyone though.
ati347 is offline   Reply With Quote
Old 01-04-2014, 12:27 AM   #14
There's one upper and it's most of the source of your problem, I assure you.....
I used the Roush upper and, while not as hardcore as the others, it did a pretty good job taming the hop on street tires. It's very intelligently designed to resist the windup, aid traction transfer and adds no nvh.
Old 01-04-2014, 12:21 PM   #15
2013_DIB_GTCS's Avatar
Has anyone used the Roush UCA with lowering springs? I'm curious to see if the pinion angle stays in spec with the changed geometry since its non-adjustable
2013_DIB_GTCS is offline   Reply With Quote
Old 01-04-2014, 01:12 PM   #16
Roush cars come lowered from the get go. The Roush upper's geometry is set around a car already and inch + lower than a stock GT.
I have 55D rear springs in the car, which are about 3/4" down from stock and all seems well. Not a lot of negative pinion angle but, one doesn't need a lot on a 3 link rear, especially when the bushes are stiffened up some.
09:50 AM
