How many RPMs are you running in manual at 70 - Mustang Evolution
Old 01-04-2014, 05:23 AM   #1
2011's Avatar
I have 331 Gears and it's 70 I am running 1950 RPM. What rpm's are you guys with 373 irunning?
2011 is offline   Reply With Quote
Old 01-04-2014, 06:23 AM   #2
Bryanw92's Avatar
I have 3.73. 2100 at 70 mph in 6th gear.
Bryanw92 is offline   Reply With Quote
Old 01-04-2014, 08:47 AM   #3
Gordito's Avatar
Same as this guy.
Gordito is offline   Reply With Quote
Old 01-04-2014, 10:29 AM   #4
2011's Avatar
Originally Posted by Gordito View Post
Same as this guy.
Thank you not much difference
Old 01-04-2014, 10:38 AM   #5
2011's Avatar
Same as this guy.
Old 01-04-2014, 10:43 AM   #6
2011's Avatar
Same as this guy.
Do you ever feel that your gears are too low driving around. Sorry I know the subject has been covered many times. Not sure if I want to swap my gears two 355's or 373's
Old 01-04-2014, 12:05 PM   #7
Rynarok's Avatar
Well, what do you mean by too low for driving around? First gear is really short - you could ignore it and just use 2nd all day if you prefer. For daily driving I don't see it being that much different than your other ratios.
For playing around, though, I think most agree 373 is the way to go unless you are forced induction (where you'd want a 315 or something)
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 01-04-2014, 12:08 PM   #8
Loc: Austin,TX
3.31 to 3.55 would be a waste. You won't even feel the difference.
Old 01-04-2014, 12:14 PM   #9
+1. I went 3.55 to 3.73 and it was a waste. Either going 3.90 or 4.10. This is my 03 cobra. Not the same car but gear results are similar.
Old 01-04-2014, 12:45 PM   #10
Loc: Austin,TX
3.31 to 3.90 or 4.10 will grab you in the boo boo. You will feel a real seat of the pants difference.
Old 01-04-2014, 01:22 PM   #11
Consider 4:10 or 4:56. 2300 RPM's are fine.
Old 01-04-2014, 01:24 PM   #12
Not a good idea with the MT82, you will be shifting every couple seconds, now if you didn't mind trapping the 1/4 mile in 5th gear it will be fast, but if you do any more power mods it will honestly be to much.
Old 01-04-2014, 07:12 PM   #13
2011's Avatar
I would not go higher than 3.73 but not sure if that would be an improvement at the drag strip and street. I'm able to launch my stock 3.31 geared mustang easily on the strip and street. My best run is in the 12's. Would I tell a difference with 3.55 and still maintain traction for a launch on street tires?
Old 01-04-2014, 11:59 PM   #14
OK, got ya.
Old 01-05-2014, 12:24 AM   #15
You will most likely notice a bit of wheel spin which can actually cut your time down a bit. What is really best for the 11+ 5.0 auto is to stick with 3.31 gears and just upgrade your torque converter. Much better results.
Old 01-07-2014, 08:02 AM   #16
2011's Avatar
I'm running a manual
Old 01-07-2014, 12:09 PM   #17
Google "RPM calculator"
MT82 gear ratios are:
3.66
2.43
1.69
1.32
1.00
0.65
Plug in your gear ratio, final drive ratio (.65), tire diameter and the speed you will be going and voila. You can see what any possible imaginable combo will be turning.
Interwebs knows all.
Old 01-07-2014, 03:52 PM   #18
2011's Avatar
3.66
2.43
1.69
1.32
1.00
0.65
Thank you
11:11 AM
