4.6 VS LS - Mustang Evolution
Old 01-08-2014, 07:49 PM   #1
Slow4V's Avatar
4.6 VS LS
My goal is to be able to run with , or even beat the C5 Corvette
I don't have much trouble taking the LS camaros or trans am
But remember getting spanked by a C5 when I first got my car with mods on his end.
Anyone think this is possible NA?
Or fully bolted and spraying ?
Old 01-08-2014, 07:53 PM   #2
Subscribed. I love bench racing.
Spray would be the quick way for sure though
CoolHorsey is offline   Reply With Quote
Old 01-08-2014, 09:22 PM   #3
Your going against 350hp and 390tq to the crank. And the fact that they are pretty light.
My parents have a C5 which I've been in many times and even driven a few times and that thing is a beast.
The only advantage you have is your 6800 redline (it's 6k for the Vette) and the 4.10s. I believe that the Vette has a 3.40 gear or something like that. But it also has the T56 (6 speed)
100% stock the C5 will pull a 12.8-13.0 quarter mile.
Honestly If he has any motor work your toast.
Old 01-08-2014, 09:26 PM   #4
Rapinator126's Avatar
You will need nitrous or boost. Won't do it NA. **** if you pull up besides a heads/cam/intake/full exhaust ls1 it will tear you a new ***. You will need alot
---------- Post added at 10:26 PM ---------- Previous post was at 10:23 PM ----------
And I said ls1 bc of your comments on the camaro etc. The c5 if it has the same mods as I listed for the ls1. You will need full boltons/ 150 + hit of nitrous
Old 01-08-2014, 09:28 PM   #5
C5 has an LS1, but they tweaked it a bit for the Vette.
Old 01-08-2014, 09:30 PM   #6
Ls6 is what is in the c5. Its a 5.7 with different heads/cam from the ls1
---------- Post added at 10:30 PM ---------- Previous post was at 10:29 PM ----------
C5 z06 I mean
Old 01-08-2014, 09:30 PM   #7
C5 z06 I mean
LS6 is the C5 Z06, regular C5 is LS1
Old 01-08-2014, 09:31 PM   #8
I figured you meant that.
Old 01-08-2014, 09:32 PM   #9
Yes I always think z06 when I think of the Vette lol
Old 01-08-2014, 09:33 PM   #10
Dirty, but here it is
Name:	ImageUploadedByMustang Evolution1389242005.970281.jpg
Old 01-08-2014, 09:38 PM   #11
4.6 VS LS
If you can beat stock Camaros and Trans ams right now then you should be able to keep to the heels of the Vette as it sits. It is a much lighter car so that's where the advantage comes in.
Old 01-08-2014, 09:50 PM   #12
Ish416's Avatar
Considering a big cam and heads C5 can put down over 450rwhp, I don't see being able to run with a C5 as something that is effectively possible NA with a mod engine.
My H/C/I Z28 has never had any issues putting several bus lengths on any NA 4.6 (2v,3v,4v), even with the Mustang on a 100/125 shot.
Also, consider a stock base C5 is a high 12 / low 13 second car at 110+mph. Most Mustangs that do that are either a blown Cobra/Shelby or a new 5.0.
To hang with a C5, you are going to have to put down around 330rwhp or gut your car several hundred pounds. At that point it should be a drivers race, unless you have a full drag setup and are on the strip.
If you want to do this NA, swap in a 6.0L LSx, get a big cam, high flow heads and a 150 shot. At that point, you should have over 600rwhp when you need it. All without spending big money on a fully built NA 4.6 (with a 150 shot) only to fall short when you run into any LSx powered vehicle with more than an intake, exhaust and tune.
Old 01-08-2014, 10:02 PM   #13
Ish416's Avatar
LS1 vettes were rated at 345hp / 350tq.
The LS6 was rated at 385hp / 385 tq for 2001 and 405hp / 400 tq for 2002+.
The C5 Z06 (2002+) was capable of high 11 / low 12 second 1/4 with a trap speed around 118 mph.
There is a reason the firing order of the LSx engines start with 1-8-7....
Old 01-09-2014, 01:16 AM   #14
1-8-7... (sigh)
08:39 AM
