Washing engine bay - Mustang Evolution
Old 01-16-2014, 02:14 AM   #1
MasonStacks's Avatar
Washing engine bay
I was just wondering the different ways people use to wash there engine bay.
MasonStacks is offline   Reply With Quote
Old 01-16-2014, 05:44 AM   #2
mystang50's Avatar
What I do is with the motor running and warmed up, not hot (like after all day of driving but like a drive to the car wash), leave it running, turn on the degreaser on the pressure washer, lightly spray the motor in a swaying motion with out squeezing the trigger, unless a nasty spot needs it (but it don't spray hard on degreaser) the with the motor running let it continue running for a couple min with the degreaser on it, then switch pressure washer to rinse, and be careful! just wave the wand over the engine rinsing it off WITHOUT pulling the trigger just do that until all the dirt/degreaser is cleaned of and take it for a little drive to let the water dry off from the fan and heat, because sitting water is bad. Then you can use armor all the shine parts up if you want after. and if you have a cai filter that is open in the engine bay, you'll have to cover it with a bag or something, just don't squeeze the trigger on rinse! you can you a cloth to wipe hard spots to! This is what I do on the stang and the truck, just no sitting water, leave motor running, and don't pull that trigger, and let it dry with a little cruise.
Old 01-16-2014, 05:45 AM   #3
bucko's Avatar
I would strongly discourage using a pressure washer, or any hose to wash off a modern engine. Many have done this, some with no ill effects, but others have poor running after doing this. There are electrical sensors under the hood, that if they get wet, they can cause idle problems, through codes, and make it a nightmare to troubleshoot.
I use a bottle of 409 and paper towels to wipe down any serious dirt in the engine bay. To keep it all at hand, I wipe it all down once a month with a seperate rag after the car gets a wash.
Old 01-16-2014, 05:45 AM   #4
mystang50's Avatar
and try not to continuously spray in one spot, just do the waving motion.
Old 01-16-2014, 05:50 AM   #5
mystang50's Avatar
but that's the fun part jk...I understand what your saying, I was just telling him what I do/have done for years on 4-5 diff vehicles. I've done your technique too which works also
Old 01-16-2014, 04:14 PM   #6
Washing engine bay
Thanks for the ideas guys! Anyone else have different ways they clean there engine bay?
Old 01-16-2014, 04:16 PM   #7
Don't spray, just wipe... Coils, alternator, battery, fuse box. All this stuff you don't want to get wet.
Old 01-16-2014, 05:28 PM   #8
Getn off's Avatar
I pressure wash away. Use a foam degreaser if needed also. Have done so for over 25 years on everything from Jeeps to Jaguars with no issues. Worst problem I ever encountered was getting a distributer wet on a 66 Chrysler. Had to dry it out and it was fine.
People think water will kill everything in ur engine bay. Just driving in rain on the freeway here in Florida gets more water in ur engine bay than a pressure washer.
Hell, i pressure wash my 2010 Wrangler's dash and seats!
To each is own.
Troy
Btw, I would be careful letting the soap/degreaser dry on a running engine...that will leave permanent spot stains on some plastics.
Getn off is offline   Reply With Quote
Old 01-16-2014, 05:36 PM   #9
To each is own.
Troy
Does depend on the car a bit... I know with the 99-04 Mustang GTs with the COPs there have been many cases of water leaking through the COP and down to the spark plug.
Old 01-16-2014, 05:40 PM   #10
Blogger
99ford's Avatar
I would avoid high pressure only because it can force water into areas that aren't supposed to get wet.
I've been using this method for years with no issues
Step 1. Make sure the engine is ice cold before starting.
You want it cool since there is a slight possibility that you can crack the engine block by throwing cold water on it.
Step 2. Cover fuse box, battery, distributor cap, air intake, and I cover the alternator as well. Plastic bags work well
Step 3. I spray the entire bay with simple green and then lightly brush with a soft brush or old rag.
Step 4. Lightly rinse, I hold the hose at an angle off to the side, keeping the nozzle on the lowest setting.
Step 5. Pull off plastic bags a little water might get onto those areas , but just wipe it up, and you'll be fine.
Step 6: Dry the bay with towels or forced air dryer (a leaf lower will work as long as the tube is clean)
At this point you have 2 options leave it alone, or dress it up to your liking! I like to use SprayWay instant shine it looks great, and it doesn't attract dust.
Note: I usually do the engine first when detailing a car, it's not mandatory, but I don't love the job enough to go back and clean the overspray up.
Old 01-17-2014, 01:26 PM   #11
Thanks for all the options guys, really appreciate it.
Mustang 2 motor swap. Curtiswhitehead 2.3 Mustang 2 07-10-2013 08:06 AM
Engine swap Bahia125 1996-2004 Mustang GT 4 02-10-2012 09:59 AM
Engine swap question!! Tominkc 1996-2004 Mustang GT 1 02-09-2012 12:15 AM
engine bay cleaning Horseplay Mustang Paint, Appearance & Detailing 10 01-27-2012 09:02 AM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 01:30 PM
08:49 PM
