Throttle body spacer - Mustang Evolution
Old 01-20-2014, 09:59 PM   #1
Is it safe to assume that the araid throttle body spacer would fit a bbk 85mm throttle body or is it made just for stock throttle body ??? Thanks ...
PonyBoy415 is offline   Reply With Quote
Old 01-22-2014, 05:50 PM   #2
NoSlo5oH's Avatar
Not sure, but I imagine it would fit. I have an Airaid spacer on my '13, but I'm still running the stock TB.
NoSlo5oH is offline   Reply With Quote
Old 01-22-2014, 06:52 PM   #3
SELENE's Avatar
Region: Oregon
I am sure it would fit, because the BBK 85 is a direct bolt-on. I also have a BBK 85 and I am curious what the real gains of the spacer are... I have thought about picking one up as well.
2013 Sterling Gray Shelby GT500
SELENE is offline   Reply With Quote
Old 01-22-2014, 09:08 PM   #4
How do you like the spacer ??
---------- Post added at 08:08 PM ---------- Previous post was at 08:07 PM ----------
Are you running a tune with the throttle body ?? I want to run both as well ..
Old 01-22-2014, 09:24 PM   #5
NoSlo5oH's Avatar
[QUOTE=PonyBoy415;1930004]How do you like the spacer ??[COLOR="Silver"]
I like it a lot...including the whistle effect that it produces. I bought the spacer because I put together a custom nitrous kit for my car in which I used the Nitrous Outlet solenoid bracket that mounts to the TB. I had to use the spacer to bring the TB out far enough for the solenoid bracket to clear the Y connector in the cooling system. I have a Bama tune on my car right now. Here are a couple of pics.
http://i1351.photobucket.com/albums/...ps32df0b1b.jpg
http://i1351.photobucket.com/albums/...ps75887b96.jpg
http://i1351.photobucket.com/albums/...ps6d2ea38a.jpg
Old 01-22-2014, 09:41 PM   #6
[QUOTE=NoSlo5oH;1930013]
That's awesome !!! Some people say the whistle can be annoying , I wasn't sure if I would even hire it with the CAI , roush axle backs with resonator delete that I run....that nitrous setup looks awesome how much hp does the coyote put out with a boost of nitro ??
Old 01-22-2014, 10:14 PM   #7
samuelsmith's Avatar
I bought one for my new intake mod. I have to have one for the install. You can see right here on the box it does not start working till 3500+ rpms. If you are not going to rev high, don't buy. I recommend polishing the upper runners for a better air vortex effect.
Old 01-22-2014, 10:33 PM   #8
The air raid spacer says it kicks in between 800-2500rpm improving torque and fuel mileage plus the infamous or famous whistle
Old 01-22-2014, 10:46 PM   #9
It sucks to have a v-6. 3500+ for us.
Whistle while you twerk them gears.
Old 01-22-2014, 11:11 PM   #10
NoSlo5oH's Avatar
[QUOTE=PonyBoy415;1930028]
Thanks! I also have a full exhaust and yes the whistle from the TB spacer is still very noticeable. My car made 519 rwhp and 551 rwtq on a 100 shot.
Old 01-23-2014, 08:34 AM   #11
A TB spacer has the effect of lengthening the intake runners and creating more plenum volume, things that will aid torque production at lower rpms, all other things being equal.
There is no such thing as a "vortex effect", that's watching too many tornado commercials on TV. This isn't the kitchen sink; the pressure waves vary within different parts of the manifold all the time, killing any possibility of some kind of "flow vortex" developing. Even if one was created, it would impede power production as what you actually want in a manifold, as much as you can get it, is laminar (smooth) flow, not turbulence.
Old 01-25-2014, 09:56 PM   #12
I received and installed my TBS on Friday , installed it and it makes a difference in the throttle response and I see my mpg climbing .....the whistle sound is cool , sounds like I have a turbo or something
---------- Post added at 08:56 PM ---------- Previous post was at 08:56 PM ----------
I think I'll get the 85mm bbk when I get my tax refund in a couple weeks to couple it up with
Old 01-26-2014, 07:54 AM   #13
I'll give you the potential for a throttle response change but, c'mon, really? mileage climbing? you've had it a couple days, kind of hard to imagine that measure is too scientific or accurate. The airraid bumf is total bull**** to anyone who knows how an engine really works. Swirling action, superior atomization, wtf? There's no fuel in the manifold to atomize. Smooth, laminar flow air, without turbulence or disruption fills th cylinder with the coolest and densest charge.
Frankly, money spent around the throttle body and associated bits, unless you're FI, is better spent elsewhere, if one is looking for a power gain. Maybe an nice off road H and/or a good tune.
Old 01-26-2014, 08:16 AM   #14
stampde's Avatar
+1
2011 GT Auto
Old 01-26-2014, 09:23 AM   #15
[QUOTE="5LHO;1932683"]I'll give you the potential for a throttle response change but, c'mon, really? mileage climbing? you've had it a couple days, kind of hard to imagine that measure is too scientific or accurate. The airraid bumf is total bull**** to anyone who knows how an engine really works. Swirling action, superior atomization, wtf? There's no fuel in the manifold to atomize. Smooth, laminar flow air, without turbulence or disruption fills th cylinder with the coolest and densest charge. Frankly, money spent around the throttle body and associated bits, unless you're FI, is better spent elsewhere, if one is looking for a power gain. Maybe an nice off road H and/or a good tune.[/QUOTE
I think it's a great value for the 117 dollars I spent ... And my mpg has went from 14.1to 14.5 already yes it's minimal but it's something .... I'm keeping my cats though so off-road is out the question
Old 01-26-2014, 09:28 AM   #16
You can keep cats with a H pipe on this thing and even with that there is more power from that than this thing. Putting this 117 bucks towards saving for a tune would also be a better choice...or just buying a couple tanks of gas. even if true, the .4 mpg increase is gonna take a long time to pay you back 117 bucks.
Again, c'mon, a lot of factors affect mpg. You think after a few days you can determine a .4 mpg increase? You need to average your results over multiple tanks, using the fuel-used method to even have a hope of accuracy here.
Old 01-26-2014, 09:38 AM   #17
Grabber Blue5.0's Avatar
I call B.S. on the mileage getting better. Waste of $117.00.
Old 01-26-2014, 09:45 AM   #18
Damn Grabber why you always gotta act like a hater , surprised you don't own a Chevy
Old 01-26-2014, 10:42 AM   #19
I tell it like I see it. And I wasn't the only one in this thread.
Old 01-26-2014, 11:03 AM   #20
66Sprint200's Avatar
Do any of you read the american muscle website. The throttlebody spacer says it's specifically designed to work with the STOCK throttle body. Its inner diameter is the same as the stock throttle body. If you use it with a larger aftermarket throttlebody you are just going to constrict the airflow from the larger throttlebody making it useless. It says this on americanmuscle's website. Some guy on there left a review because he used one of the throttlebody spacers with a BBK throttlebody and it actually made his performance worse.
1966 Mustang Sprint 200--Wimbledon White
1998 Mustang V6 Coupe--Silver--RIP, Totalled by brother
2005 Mustang V6 Premium Coupe--Sonic Blue
66Sprint200 is offline   Reply With Quote
Old 01-26-2014, 11:07 AM   #21
SELENE's Avatar
Region: Oregon
+1 - You are correct. It would be a step backwards if you already have a larger aftermarket TB.
Old 01-26-2014, 11:27 AM   #22
At what hp. is it sufficient to upgrade to a larger tb.?
Old 01-26-2014, 11:38 AM   #23
I don't know how many times I looked on AM at that spacer and I overlooked what it said right there wow....it only works with the stock throttle body...
Old 01-26-2014, 11:46 AM   #24
Sorry if my post sounded kinda like a jerk, I didn't mean it to come across that way. But yup, the spacers are to increase the performance of the factory throttlebody. It's for those of us who can't afford the $300,$400+ aftermarket throttlebodies. I've been looking at getting the Airaid spacer for a while.
Old 01-26-2014, 11:55 AM   #25
All good...
Old 01-26-2014, 01:18 PM   #26
let's put it this way: there are plenty of 600+ horsepower FI cars out there on the stock TB. there is no way in hell a TB is going to justify its cost in an NA stock-ish application.
Airaid Poweraid Throttle Body Spacer (11-14 GT) 2013fiveO 2011-2014 Mustang GT 29 06-12-2014 02:56 AM
throttle body spacer do they really work? shunc01 2005-2010 V6 Mustang 6 01-14-2012 01:13 AM
Throttle Body? 2011CS 2011-2014 Mustang GT 2 11-14-2011 06:28 AM
Throttle body spacer? Mayhem48 2011-2014 V6 Mustang 1 08-16-2011 10:41 PM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 08:43 PM
07:44 AM
