Ford Racing Hot rod cams - Mustang Evolution
Old 01-23-2014, 09:42 PM   #1
32GT32's Avatar
Well I've been saving up a lil and I decided I want to buy the ford racing hot rod cams the things I wanna know is have any of you guys had any problems with this set up? What will I need? Could you tell a big difference in performance? What should I expect right now I have the jlt 3 series cai 91bama Oct custom tune pypes catted x pipe and pypes bomb axle back when I install the cams I'm going to change out the x pipe and go with jba long tubes jba offroad hpipe and stay with the axle back I also want to add the ford racing intake manifold and steeda udp what will I need for the UDP? I don't plan to do it right away it might take me 3 or 4 months considering I'm still in school but income tax should help a lil so well see what happens
32GT32 is offline   Reply With Quote
Old 01-23-2014, 10:43 PM   #2
gt07's Avatar
if you like the look of that racing intake....cause it does not add much power save some money and get some steeda charge motion control plates and a larger throttle body instead.....the cams have a very cool idle and at higher rpms is where you are going to find any hp and may lose a little off the line..before you get those cams get some steeper gears 3.73 or 410s......hope this helps .....finding someone with that same set up is going to be like finding a needle in a hey stack
gt07 is offline   Reply With Quote
Old 01-24-2014, 10:19 AM   #3
2300turboford's Avatar
I wouldn't get the hot rod cams I would go to a different company like brenspeed or comp cams I have heard some bad things on the hot rod cams
Old 01-24-2014, 10:22 AM   #4
32GT32's Avatar
Oh really bad things like what?
Old 01-24-2014, 10:29 AM   #5
32GT32's Avatar
Yeah I was thinking of going 4.10 gears and have you had the intake manifold?
Old 01-24-2014, 10:39 AM   #6
gt07's Avatar
I don't have that intake manifold but I do have the motion plates very pleased with them.Easy to install and response is great.i have the gt500 throttle body twin 60 mm.is about an inch bigger than stock .....what year is your gt?
Old 01-24-2014, 10:45 AM   #7
gt07's Avatar
I got the throttle body from late model restoration it comes pre drilled and with the spacer bolts right up but hat to get a throttle body to intake adaptor from silicone intakes there's did not match up it was 12 dollars
Old 01-24-2014, 10:47 AM   #8
Srry I was thinking about the mutha thumper cams
Old 01-24-2014, 10:53 AM   #9
gt07's Avatar
I know two people with that intake and they said they did not get anything noticeable other that the same throttle response that i got with the steeda motion control plates.....but they do look very nice......good at the car shows ..
Old 01-24-2014, 10:54 AM   #10
32GT32's Avatar
My gt is a 2010 and I want a throttle body I wanted the twin 60 mm gt 500 like yours but i don't think I can use that one Kuz I have the jlt series 3 intake I've heard it won't fit?
Old 01-24-2014, 10:57 AM   #11
32GT32's Avatar
Well I knew the manifold would do the same they delete your charge motion plates I believe and it is a lil pricey I would of expected it to help top end though that's what my car needs to improve on
Old 01-24-2014, 10:59 AM   #12
32GT32's Avatar
Oh ok lol what about the hot rod cams?
Old 01-24-2014, 11:05 AM   #13
gt07's Avatar
I like the sound of them if you have manual trans needs a little more gas to get going ....I you have an auto you may want to get a high stall converter 2800 or 3000 and the 4.10s and still may lose a little 60 ft out of the hole but will get it back after 3000 or rpms and higher
Old 01-24-2014, 11:09 AM   #14
gt07's Avatar
ok your intake manifold may have those plates may be built into it sorry not sure.... those plates are for 05 to 09 gts
Old 01-24-2014, 11:11 AM   #15
32GT32's Avatar
I have an auto and now Im thinking of doing what your telling me about how much would I spend on the gears and stall do you know?
Old 01-24-2014, 11:13 AM   #16
32GT32's Avatar
Yeah there's a couple of things that differ from 05-09 to my year model I don't know why if we have the same motor
Old 01-24-2014, 11:26 AM   #17
gt07's Avatar
the price at American muscle is 279.99 for the 410s and 319.99 for the throttle body .....late model restoration has the throttle body pre drilled that's where I got mine ......silicone intakes they have the spacer you will need .....take a string and wrap it around your throttle body mark the string and measure it then do the same to your intake use the to measurements and order the coupler from silicone intakes 12 or 13 bucks
Old 01-24-2014, 11:32 AM   #18
gt07's Avatar
I had a vacume line in mine from the cold air intake side I took a paper hole punch and made a hole for the tube a small amount of high temp silicone on the inside of the flanged tube and it worked perfect
Old 01-24-2014, 11:52 AM   #19
gt07's Avatar
tci torque converter 519.99 mine is sitting on my work bench in the garage waiting for warmer weather
Old 01-24-2014, 11:58 AM   #20
Vistablue's Avatar
I have the hot rod cams. I love them and with pypes mid muffler pipes it's pretty loud even with cats. Once I installed them, later that week I was installing 3.73 gears. Top end is awesome, but with 3.31 gears, the bottom end was horrible. Does sounds good and makes good power. I always have ppl asking me about them. I have also had 0 issues with them.
Vistablue is offline   Reply With Quote
Old 01-24-2014, 12:27 PM   #21
Edd204's Avatar
I also have those cams, and love them. Have had them for 2 summers and have had no issues. I got 3:73 gears installed and it drives great. I have manga flow high flow cats, and ford racing headers and exhaust and it sounds awsome. Going thru a restaurant drive thru is always fun, when all they hear is that idle lol.
Edd204 is offline   Reply With Quote
Old 01-24-2014, 12:38 PM   #22
32GT32's Avatar
I don't think the gt500 twin throttle body will fit mine because of my cold air
Old 01-24-2014, 12:40 PM   #23
32GT32's Avatar
Yeah see that's what I have 3.31 gears are terrible! I need a lil top end help people say to stick to 4.10 though if your auto and 3.73 if manual
Old 01-24-2014, 12:41 PM   #24
32GT32's Avatar
I beat you turn a lot of heads !
Old 01-24-2014, 12:46 PM   #25
Vistablue's Avatar
I wish I could turn back time and put 4.10s in. i seriously regret it. Lol but mines a 5-speed.
Old 01-24-2014, 12:52 PM   #26
32GT32's Avatar
Really why is that
Old 01-24-2014, 12:54 PM   #27
Edd204's Avatar
Yea it definatly does. Lol. Wish I could pull it out and take her for a spin but it's winter here and it's parked untill summer.
Old 01-24-2014, 12:55 PM   #28
32GT32's Avatar
Where you from Budd? Its getting warm down here already
Old 01-24-2014, 12:59 PM   #29
Edd204's Avatar
I have an auto and was debating back and forth when purchasing the gears. Asked arouund abit and based on what I was looking for , some said id be happy with the 3:73, But I have a kenne bell on aswell and im happy with the 3:73
Old 01-24-2014, 01:00 PM   #30
Edd204's Avatar
Manitoba , Canada. We have been having like bone chilling cold whether
Old 01-24-2014, 01:03 PM   #31
Vistablue's Avatar
Really why is that
I mean I love them. Just want more pin you in the seat. Lol it's cool here too . All that Canada air were getting.
Old 01-24-2014, 01:07 PM   #32
32GT32's Avatar
Lol I would be too if I had a benne bell
---------- Post added at 03:07 PM ---------- Previous post was at 03:06 PM ----------
That's crazy man I'm from Texas so we hardly see any snow here
Old 01-24-2014, 01:10 PM   #33
Edd204's Avatar
That friggen Canadian air ! Lol I hate this cold. But I wish we had Texas weather . I hate snow. All I can do is read mustang mags till summer haha
Old 01-24-2014, 01:22 PM   #34
32GT32's Avatar
Lol cold weather does suck! Bet you can't wait to drive your stang again
Old 01-24-2014, 01:46 PM   #35
Edd204's Avatar
Oh man. Counting down the days till spring. Usually winter I'll buy and stock up on new stuff for the car. So once spring comes I have all this cool new stuff to install. Are u planning on installing cams yourself?
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
Hot rod...F-250? Otlaw80 General Car Discussion 0 08-25-2011 09:16 PM
ford racing B&E 303 cams C4king General Car Discussion 0 07-26-2011 10:11 PM
Ford Racing Power Pack MALS Marine 2005-2010 V6 Mustang 7 06-30-2011 09:07 PM
12:29 PM
