2014 vert with lowering springs. Shock? - Mustang Evolution
Old 01-27-2014, 05:09 PM   #1
I just lowered my vert in the garage. Stock springs to eibach pro. Haven't had it on the road yet. Live in NW Pa. Snow belt country. Anyway. Thoughts on shocks ? Will the factory do ok? The vert is/was a softer setup... Rear shocks vs struts ? One or the other? anybody have insight to share? I want it handle better
jzaphiris is offline   Reply With Quote
Old 01-27-2014, 05:37 PM   #2
11stangGT's Avatar
Region: Arkansas
Stock are ok if you just wanna get by.. Replacements are ideal.
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 01-27-2014, 06:23 PM   #3
HPFury's Avatar
Koni shocks...yellows if your budget allows. I went with ford racing myself.
HPFury is offline   Reply With Quote
Old 01-27-2014, 06:32 PM   #4
11stangGT's Avatar
Region: Arkansas
Koni, steeda, ford racing all pretty good
Old 01-27-2014, 06:34 PM   #5
Eibach any good?
Old 01-27-2014, 06:35 PM   #6
HPFury's Avatar
Billstein's are good also.
Old 01-29-2014, 01:47 AM   #7
Red Stallion 11's Avatar
Koni str.t are on sale but keep in mind changing the shocks and struts that you will also need camber plates
Red Stallion 11 is offline   Reply With Quote
Old 01-29-2014, 07:31 AM   #8
Why? Unless the drop is ridiculous, all you need is matching strut mounts, as most aftermarket struts want the 2010 style.
Factory struts and shocks are a a touch weak on stock springs...and I have a Brembo car. The vert stuff is even less likely to be ideal.
Old 01-29-2014, 07:41 AM   #9
So koni oranges all around and new gt500 strut mounts and that should be it?
Old 01-30-2014, 03:45 PM   #10
HPFury's Avatar
Yes if you don't plan to lower more than 1". Camber bolts or cc plates also if you are lower than this.
Old 02-02-2014, 02:28 AM   #11
Region: Oregon
I like Eibach myself. Not expensive at all and have never had problems with them.
Instafire is offline   Reply With Quote
Old 02-02-2014, 05:11 AM   #12
Just took it out on the road. Wow. Different car! Tight and controlled. Can't wait to get koni s on
lowering springs Marty5.0 2011-2014 Mustang GT 12 01-21-2014 08:57 AM
SVE lowering springs with kyb strut and shock kit???? mcvicar04 1996-2004 Mustang GT 1 12-07-2011 09:04 AM
lowering springs Cantlin01 1996-2004 Mustang GT 8 12-01-2011 02:45 PM
Lowering springs 89white GT 1979-1995 Mustang GT 13 08-31-2011 09:32 AM
Lowering springs 89white GT AmericanMuscle 1 08-30-2011 04:11 PM
04:07 PM
