Do I need a tune for CAI? - Mustang Evolution
Old 01-29-2014, 04:46 PM   #1
randyg's Avatar
Region: Iowa
Hey all,
I am going to buy a Steeda tune. My first question: where do I find the numbers on the computer to give them?
Second question: Will a CAI benefit from the tune or should I just leave well enough alone and not get the CAI?
Thanks
Randy
randyg is offline   Reply With Quote
Old 01-29-2014, 04:49 PM   #2
air_commando88's Avatar
I'm not sure on the numbers but if your getting a steeda cai as well it requires a tune. Some don't but it benefits you little without the tune other than making the engine sound more prominent.
Sent from my HTC6435LVW using Mustang Evolution mobile app
air_commando88 is offline   Reply With Quote
Old 01-29-2014, 04:50 PM   #3
ArtU's Avatar
Originally Posted by randyg View Post
Hey all,
Thanks
Randy
A Steeda Tune will ROCK with a Steeda CAI. It is the only CAI [that I am aware of] that requires a tune for the V6 because it flows more air. Other than that, the Stock Air box flows as much as the other CAIs, just doesn't make the fun noise. Also you can get a high flow AFE blue permanente filter for your stock airbox if you wish.
Standing by the passenger side look at your computer just past the white water bottle with the yellow cap. You will see bar codes and numbers on it. There will be a number at the bottom that is like 4 letters/number long then the long bar code. The ~4 characters is the Strategy code for your computer. As an example mine in stickered from the factory at LLH3
Old 01-29-2014, 04:56 PM   #4
randyg's Avatar
Region: Iowa
Thank you for the quick reply. I guess what Im asking is will I see any noticeable gains, not counting noise with the CAI. They offer a package on both the CAI and tune. I already have 4.10 to install.
Thanks
Randy
Old 01-29-2014, 04:59 PM   #5
You will pretty good gains just don't expect to be blown back into your seat
Old 01-29-2014, 05:27 PM   #6
ArtU's Avatar
Thanks
Randy
I noticed better gains with the Steeda CAI over stock airbox with AFE high flow filter. I feel it was money well spent and also looks good under the hood.
Edit: Need to comment here that that effect was not due to just a tune. I had tunes before the Steeda CAI. But when the Steeda CAI was added and required modification to the tune, then it was the very noticable difference in the equation.
Old 01-30-2014, 01:00 AM   #7
2 Stangz's Avatar
Region: Nevada
Awesome! Just got my Steeda tune today and the Steeda CAI has been on my list for a while. Can't wait to pick it up.
Old 01-30-2014, 01:17 AM   #8
Loc: Austin,TX
Skip the CAI. Its a waste on these cars. The tune is where its all at.
Old 01-30-2014, 05:30 AM   #9
blu
blu's Avatar
Get the CAI and the tune. But to finish the potential of this particular bolt on mod in hp, do exhaust next, and put an x pipe on with some free flowing axle backs.
2011 GT Prem Kna Blu
"Quick like a Snake, light like a Fox. This remains the goal."
blu is offline   Reply With Quote
Old 01-30-2014, 05:42 AM   #10
ArtU's Avatar
I would agree with that on all except the Steeda.
Old 01-30-2014, 10:22 AM   #11
blackbeauty 2's Avatar
I got the arh long tube headers with a airaid can and a throttle body spacer with borla atak I'm really impressed with the results
blackbeauty 2 is offline   Reply With Quote
Old 01-30-2014, 02:23 PM   #12
bucko's Avatar
What DDTCM says. Do some homework. Ford really did some great engineering on the stock air boxes. Hard to beat them. A tune wakes it up.
Other than cosmetics and the sound you get from a CAI, they really will not flow any more air significantly than the stocker.
And if you want the sound/roar that the CAI provides when you stomp the drive by wire pedal, then cut off the square muffler off the tube and fiberglass the hole. Now you have the same benefits of a CAI.
Old 01-30-2014, 08:59 PM   #13
ArtU's Avatar
I will add a post script to that. I knew what Bucko says is true and that the stock airbox was better than the CAI, being it is a ram-air feed cold box from the factory. I did research and that was the story.
I got a tune first on the stock airbox and that was great. I added the Steeda CAI after the stock airbox tune and guess what, it did have gains. Talk to "Rod" at Steeda if you need info.
Edit: that's the reason its the only one that "requires" a tune to use because yes the MAF area in the Steeda tube is larger
PPS: Yes after that part of the tube, some say it forces the air into a smaller Throttle Body. But It has improved MID Torque (2.5-3.8 rpm) in my ride on several test runs. the only sensor unfortunately has been my *** in my seat , sorry
Last: The Steeda CAI also is one that gets feed also from the "grill ram air" feed that the stock airbox gets air from. It has the "grill feed" on a connector on the bottom the same as the stock box does.
Old 01-31-2014, 01:57 AM   #14
2 Stangz's Avatar
Region: Nevada
Steeda's cold air intake for the 11'-14's seem to really be impressive. I believe it's the best on the market with no competition. Just read Steeda's blog and it may change your mind if you have any doubts.
Gains or no gains from it though, I'd still like to have it on my ride. It's a great look and I've really come to admire Steeda as a company and the parts they sell. However, I'll probably be getting headers first, as the stock cold air induction is nothing to complain about either.
Old 01-31-2014, 04:14 AM   #15
bucko's Avatar
Was the "bang for the buck" worth the $389.95 over keeping the stock air box?
I'll agree with the stats and dyno sheet results that with a tune, the steeda air box provides the best gain over other CAI's...but how much more over a stock air box and the same tune? Does anyone here have a stock air box and tune, and steeda CAI and (same) tune dyno results they can share?
cai
Custom vs. Strategy Tune (BAMA SCT) Rynarok AmericanMuscle 63 06-17-2013 09:21 AM
Need help! eouellette18 2005-2010 Mustang GT 10 03-25-2013 01:18 PM
Bama 93 series tune issues after H-Pipe install 2013_stang_gt 2011-2014 Mustang GT 7 09-26-2012 04:31 PM
Bama ghost tune. 86custom 2011-2014 Mustang GT 138 08-02-2012 03:22 PM
CAI tune to stock? Aggiesrok 2005-2010 Mustang GT 8 01-16-2012 04:39 PM
08:44 AM
