It has finally happened :( - Mustang Evolution
Old 02-03-2014, 10:41 AM   #1
Adogg's Avatar
Name:	ImageUploadedByMustang Evolution1391448488.825738.jpg
Well as you all can see my baby just hit 150k last night. She doesn't run or look like she has that many mile but sadly she does. This has really got me thinking maybe I should start saving for a new motor before something happens or should I just mod this motor? Is 150k a bad amount of miles for these cars?To be honest with all of you if I were to get another motor it would be another cheap low miles 302, and mod that motor little by little as I got the money. As of right now she isn't my dd so she isn't getting that many miles put on her. Just going to get her running perfect and better suspension. I'm open to all suggestion and help.
Thank you,
Adogg
Don't hate....... appreciate
Old 02-03-2014, 11:20 AM   #2
SixBanger's Avatar
150k? She's not even broken in yet.
My dad has an 02 GT which recently hit 300k. I'm not sure exactly what mods he's done but I'm certain that it's a long list. Still, 150k isn't "bad." Just make sure you are keeping up with the maintenance which is explained in your owners manual. As a car gets older, more intensive maintenance is required than your simple oil changes so make sure you are keeping up, otherwise you won't make it much further.
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 02-03-2014, 11:24 AM   #3
Adogg's Avatar
Thanks man, I was planning on doing a pretty big tune up when summer hit, I already replaced the spark plugs and spark plug wires, and distributer also cleaned some censors.
Old 02-03-2014, 01:40 PM   #4
Do a compression test/leakdown check. If it passes go nuts. I've seen these things break 200k+ no sweat. As long as you've been good about maintenance, regular oil changes, cleaning the air filter etc... these things can last a very VERY long time.
If it does blow up for some reason its just an excuse to go find a lower mileage explorer motor and throw a S trim at it.
Old 02-03-2014, 02:01 PM   #5
Adogg's Avatar
Nice thank you for the advice. What are your thoughts on the bbk under drive pullies? They a good way to pick up power for cheap? Going to do a few suspension mods too but don't wanna spend a million dollars, what would you recommend first?
Old 02-03-2014, 02:15 PM   #6
I had the aluminum BBK UD pullies on my 95 for years. Great pieces and one of the only BBK things I would recommend.
Old 02-03-2014, 02:20 PM   #7
Adogg's Avatar
Really? Nice!! For the price they are they seem worth it. You didn't have any trouble with them? How was the performance gains?
Old 02-03-2014, 02:25 PM   #8
Little bit of a sotp gain, not huge but every bit helps in bolt on land. I did not install the alternator pulley. No point for less than 1hp and the potential for charging issues. Just the water pump and crank.
Just make sure to save your stock pullies in case you ever put a supercharger on.
Old 02-03-2014, 02:28 PM   #9
Adogg's Avatar
Ooooo alright, that's what I was thinking about, cause ppl complained about charging issues. Thanks for the help again. Sorry if I'm coming off a little annoying but any recommendations for suspension with these cars?
Old 02-03-2014, 02:38 PM   #10
Adogg's Avatar
Would you buy the trick flow ones?? I love the blue they come in.
Old 02-03-2014, 02:46 PM   #11
Honestly they're pretty much all the same.
Finally on the road choppa5307 1979-1995 Mustang GT 24 02-06-2012 11:35 PM
Finally bought my new 2004 TheJigShow 1996-2004 Mustang GT 21 10-04-2011 06:52 PM
Finally Jordan Pre-2005 V6 Mustang 2 09-29-2011 01:29 PM
Finally pulling the 3.8! - Hooking it up question Black_Sunshine Pre-2005 V6 Mustang 2 09-29-2011 12:33 AM
suspension is finally installed! tigercrazy718 2005-2010 Mustang GT 8 08-18-2011 11:09 PM
10:13 PM
