Camber bolts - Mustang Evolution
Old 02-04-2014, 02:31 AM   #1
Oh2freshstang's Avatar
Camber bolts
How will camber bolts hold up at the drag strip? I go every one in a while & I'm wondering if hard launches at the drag strip would put too much stress on these or will they hold up just fine since they're on the front wheels? Thanks for any info.
Old 02-05-2014, 08:48 PM   #2
Bump.
Old 02-06-2014, 12:30 PM   #3
tj@steeda's Avatar
I would not recommend camber bolts on any vehicle that goes on a track. They are weaker than the factory bolt. Not worth taking a chance on. If one fails on the street, you will at least only be going street speeds. If it fails on the track at full throttle, your hitting the wall.
I would recommend, and not because I work for them, but a good set of Steeda HD mounts.
An Often Overlooked Handling Secret « Steeda Blog
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
Win A $300 Gift Card
tj@steeda is offline   Reply With Quote
Old 02-06-2014, 12:51 PM   #4
2 Stangz's Avatar
Region: Nevada
Best Regards,
TJ
That's a great read^
I've learned a lot of great info from their blog.
Old 02-06-2014, 02:36 PM   #5
I would not recommend camber bolts on any vehicle that goes on a track. They are weaker than the factory bolt. Not worth taking a chance on. If one fails on the street, you will at least only be going street speeds. If it fails on the track at full throttle, your hitting the wall. I would recommend, and not because I work for them, but a good set of Steeda HD mounts. An Often Overlooked Handling Secret « Steeda Blog Best Regards, TJ
Thanks for the info TJ. I'm gonna invest in some cc plates. Thanks for a good read too!
Old 02-06-2014, 04:21 PM   #6
Grabber Blue5.0's Avatar
The chances of one breaking is slim but if it does you're in deep shiit. Another option is the GT500 strut mounts with 05-10 struts. Proven combo at the strip especially if you use the Strange adjustable struts.
Old 02-06-2014, 08:37 PM   #7
Yea id rather not take the chance with camber bolts at the track.
Would u be able to get the camber back to spec with that combo & no camber bolts?
Old 02-07-2014, 09:29 AM   #8
Most likely yes unless the drop was significant. What you would do is install the strut mounts with the arrows pointing in as opposed to stock ride height with the arrows pointing out. That should get you your camber back.
Old 02-07-2014, 02:42 PM   #9
Ah ok awesome thanks!!
Old 02-07-2014, 03:25 PM   #10
Another thing is GT500 strut mounts are a nice unit and very strong and much cheaper than caster/camber plates.
Old 02-07-2014, 03:44 PM   #11
KARgt13's Avatar
I had a problem with GT500 Strut Mounts and camber bolts on a 1" drop in the front, only on the passenger side. Even with the bolts they couldn't get it aligned. Apparently I am the only person who has had this problem though.
KARgt13 is offline   Reply With Quote
Old 02-07-2014, 05:31 PM   #12
Yea they're a good deal! I actually just pulled the trigger on some eibach coilovers that I found used I'm probably gonna have to go with cc plates incase I decide to go low I'll have the ability to adjust the camber!
Old 02-07-2014, 05:35 PM   #13
Wow that sucks! Did u try turning the mounts the opposite direction like grabber said?
Old 02-07-2014, 05:57 PM   #14
KARgt13's Avatar
Unfortunately no. But now that I see that, I bet that could have been the problem. I followed a write up on latemodelrestoration but I can't remember anything about switching the direction. I installed the arrows the same way on both sides though.
Old 02-07-2014, 06:17 PM   #15
Could be wroth a shot rotating them! I think they are suppose to go the same direction but rotating them can help to fix a camber issue!
Old 02-07-2014, 06:26 PM   #16
KARgt13's Avatar
They elongated the holes in the strut tower to get it aligned. I thought I'd regret agreeing to that but they assured me it's not uncommon and in almost a year I haven't had or noticed any problems.
Old 02-07-2014, 08:13 PM   #17
Oh ok at least u got it fixed! I have heard of them doing that!
Eibach Camber Bolts 08Mustang Pictures and Videos 7 01-17-2014 01:48 PM
motor mount bolts squeaking gblegal 2011-2014 Mustang GT 5 11-11-2013 07:44 PM
Ordered springs, panhard bar & camber bolts from AM dobypaw3 2011-2014 V6 Mustang 10 07-13-2013 10:23 AM
Strut Tower Brace Bolts Blakhwk Pre-2005 V6 Mustang 21 06-14-2013 09:48 PM
Eibach camber bolts bullitt1075 General Mustang Discussion 2 11-30-2011 12:18 AM
06:08 PM
