Exhaust install help - Mustang Evolution
Old 02-04-2014, 09:53 AM   #1
Milehigh STK's Avatar
This is my first time doing an exhaust and I need some help! So I recently received my Mac off road prochamber and flow 10s. I just called around a little to look to get quotes on the job, but none of the shops will install the off road midpipe. How do I get this done?
Milehigh STK is offline   Reply With Quote
Old 02-04-2014, 10:38 AM   #2
89GTstanger's Avatar
Man thas a pretty easy install. The hard part will be getting the bolts broke loose. Coat it with WD40 . If you can work a socket wrench you can change the exhaust. Should only take a couple hours. Are you dumping it or adding over axle pipes? If you want the over axle puoes that may be an issue because you dont have a pipe bender. I always dump mine. The reason a shop won't do it is because its against the law for them to remove you catalitic converters.
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 02-04-2014, 10:40 AM   #3
Well it's a mid pipe only made for a gt and I've got a 6 so it requires welding.
Old 02-04-2014, 10:42 AM   #4
Oh...dang. yeah that may be a problem...lol
Old 02-04-2014, 10:46 AM   #5
They said they could just weld it on after the cats, but I dont want cats haha D:
Old 02-04-2014, 11:42 AM   #6
Mile high JDF's Avatar
Maybe get an exhaust shop to make it fit and not install it? If they can do that then I can get it installed for you
Sent from my XT1030 using Mustang Evolution mobile app
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-04-2014, 11:44 AM   #7
That's a brilliant idea! I'll ask about that
Old 02-04-2014, 02:47 PM   #8
Getn off's Avatar
Rent a uhaul and trailer it in. If its not for the street, it don't need cats, and they should do it.
Troy
Getn off is offline   Reply With Quote
Old 02-04-2014, 03:06 PM   #9
How much does that cost? Haha
Old 02-04-2014, 03:58 PM   #10
Troy
He means if it's not a street legal car then you can just tow it to their shop and have them install it. But since it's your DD that doesn't work
Old 02-04-2014, 10:56 PM   #11
Getn off's Avatar
Actually works very well...did it with my Goat.
Troy
Old 02-04-2014, 11:22 PM   #12
Troy
Him interesting. I'd assume you took the plates off when you towed it in?
Old 02-05-2014, 11:51 AM   #13
Getn off's Avatar
Nope. Plates just say that it was street legal at the time of registration. U can take any street legal car and decide to only use it on the track, ie not federal or state roads....and still keep the plates on.
Another option (that I did many years ago) is tell them to make u a test pipe with ur parts. That way, they will build a cat delete pipe and u can go home and install it when u want.
Troy
Old 02-05-2014, 12:57 PM   #14
Troy
Hmm that's good to know
exhaust
Question about pricing of my exhaust Dvest1995 General Mustang Discussion 9 02-04-2014 10:06 PM
Dual exhaust? Crafty615 Pre-2005 V6 Mustang 105 06-07-2012 10:22 PM
Tuner vs Exhaust? JCOB72 1996-2004 Mustang GT 43 03-07-2012 05:38 AM
First Mustang exhaust questions currambero13 Pre-2005 V6 Mustang 2 01-29-2012 09:47 PM
Different exhaust on v6 with PP? 2012Stang4Me 2011-2014 V6 Mustang 5 11-02-2011 09:05 AM
12:55 AM
