adj panhard bar - Mustang Evolution
Old 02-04-2014, 11:09 PM   #1
adj panhard bar
Doesnt centering rear axle using adj panhard bar effect pinion angle?
winkawak is offline   Reply With Quote
Old 02-05-2014, 04:33 AM   #2
Grabber Blue5.0's Avatar
No.
Old 02-05-2014, 08:27 AM   #3
Are you sure? My rear has an 3/4 of an inch offset from factory and im thinking about installing a adj phb to correct it. Is front wheels adjustable side to side so it can be aligned parallel to the rear after installation.
Old 02-05-2014, 08:35 AM   #4
Yes I'm sure. Has nothing to do with pinion angle.
Old 02-05-2014, 02:06 PM   #5
NewMtang's Avatar
Your confusing the Pan Hard Bar with the Rear Upper Control Arm.
Old 02-06-2014, 10:58 PM   #6
Region: Oregon
is the upper control arm the only way to adjust pinion angle?
Instafire is offline   Reply With Quote
Old 02-06-2014, 11:40 PM   #7
Silver06GT's Avatar
Yes. If you have adjustable lowers you have to watch your rear end position front to back and side to side (side to side shouldn't move). If you start to move and adjust one thing another with get out of whack. If you don't have adjustable lowers an LCR bracket is recommended.
Silver06GT is offline   Reply With Quote
Old 02-07-2014, 08:20 AM   #8
tj@steeda's Avatar
The main function of the panhard bar is to provide the ability to adjust rear end offset. Our larger urethane bushings on the street model reduce flex and improve the panhard bar’s control resulting in better steering response and handling balance while maintaining low NVH (noise, vibration and harshness). If you’re a road race aficionado we also carry our track tested race version bar with spherical rod end bushings for the ultimate in rigidity and hard cornering capability.
Setting the Bar – Steeda’s Improved Panhard Bar « Steeda Blog
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Maximum Motorsports Panhard bar opinions back n a stang 2011-2014 Mustang GT 0 09-09-2012 09:25 AM
Adjustable panhard bar gtstyles2 2011-2014 Mustang GT 7 10-08-2011 04:05 PM
Panhard Bar Adjustments JonChambers03 2005-2010 Mustang GT 6 07-29-2011 01:59 PM
Adjustment of panhard bar poloka 2011-2014 Mustang GT 9 07-17-2011 01:29 PM
Panhard Bar and Rod Support Suggestions poloka 2011-2014 Mustang GT 22 07-02-2011 07:56 PM
12:06 AM
